Put amp in chassis, then, right channel doesn't work!
Old 31st July 2008, 04:44 PM   #1
ambience exists is offline ambience exists  United States
ambience exists's Avatar
Default Put amp in chassis, then, right channel doesn't work!
I put my S-5 kit in a chassis made of an aluminum pan and when I flipped it on the right channel didn't work. I took a voltage measurement on the three OPT leads that go into the transformer and they all read OK, but there was zip coming out of the other side connected to the binding posts! What could be wrong here? When I touch the signal leads going into the PCB, there is no "buzz".
If anyone can help that would be great.
Thanks,
((AE))
((AE))
Old 31st July 2008, 05:10 PM   #2
heres a picture
((AE))
Old 31st July 2008, 05:20 PM   #3
On Hiatus
SY's Avatar
"No sound" can come from anywhere in the circuit. I'd start comparing DC voltages between the channels right from the input stage on through to the output.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st July 2008, 06:11 PM   #4
Is there any possibility of ruining a transformer? I had to desolder it from th e board and then re soldered it.
((AE))
Old 31st July 2008, 06:16 PM   #5
On Hiatus
SY's Avatar
Unlikely. Fortunately!
Old 31st July 2008, 07:33 PM   #6
I have checked and checked the wiring inside the amp visually, cleaned up the wiring by re soldering some things, and just tested it again and still no sound.
I am not sure where to put my volt meter for tests though, could I have not put in a coupling cap right?
((AE))
Old 31st July 2008, 09:09 PM   #7
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Did you check that the speaker terminals are isolated from chassis?
Measure the voltage to ground at all tube socket pins for both channels. Same or close on both channels? Good. If not, you have a clue where to look in the circuit. Clip one probe to the chassis, use only one hand for measurements. A shock from one arm to the other can be fatal!
If the voltages are correct, you have also narrowed the problem down. Look for a short to ground at input or output (the only places that DON'T have a DC voltage).
Old 1st August 2008, 01:01 AM   #8
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
On their kit that I bought, the hole they supplied for you to connect the volume control shaft to ground, was actually connected to the inputs of one of the channels instead.
So, if the shaft of your pot is now grounded, and you still have that wire going from it to the board, make sure it's actually going to audio ground and not the hole that they supplied. Since how they had it would short out one of the inputs when you mount it in a grounded chassis.
If that is not it, check to make sure the speaker terminal is not shorted to ground. Although, keep in mind that if your audio ground is mains grounded as well, you will measure continuity because you will be measuring the DCR of the output transformer. But that continuity should not be less than the resistance of the output transformer secondary.
Old 3rd August 2008, 09:07 PM   #9
I know that the speaker posts are isolated, because with my multi on AC, I measure signal all the way up until somewhere between the first tube grid and the OPT. There is no signal from the OPT! Help!
((AE))
Old 4th August 2008, 04:18 PM   #10
OK, I'm all set, it WAS the binding posts! It was touching the metal and was shorted. Just shows what a noob knows!
((AE))
Put amp in chassis, then, right channel doesn't work!Hide this!Advertise here!
My scope doesn't work - need help! Giaime Equipment & Tools 17 23rd September 2011 06:47 AM
Counterpoint SA100 one channel doesn´t work Orgonom Tubes / Valves 3 14th January 2007 04:21 PM
Right Channel on my amp doesn't work?? nicku1302 Solid State 2 29th November 2005 03:58 PM
why o why doesn't this work ? Balanced 549 SpaBlauw Chip Amps 15 26th January 2004 08:06 PM
Copyright ©1999-2017 diyAudio
