| diyAudio Sponsor | ||
#1 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
Does anybody have a good looking budget solution for covering budget (open frame) output transformers? I have a pair of the new Edcor GXSE that I was planning to run with 450V B+, and with kids it seemed like a good idea to have these covered. I don't really like the "cage" look, but was looking for some sort of smooth metallic box-like structure which wouldn't cost more than the transformers themselves. Any good thrifty ideas out there? -Thanks |
#3 |
both will hide a number of errors and ugliness...
Like this http://www.iol.ie/~waltonaudio/pcl86.html
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#4 |
I used Twinings tea tins upside down on one project- with matt black crinkle finish they looked great!
#5 | |
Wow, that really looks nice. I was originally thinking metal, but MDF painted a nice shiny gloss color probably wouldn't really look much different. I also like the way you made the chassis from flat aluminum plates. I think I might try painted MDF sides and nice shiny aluminum plate screwed down on top. Thanks! |
#6 | |
I had thought about using tea tins. Did you just screw the lid upside down to the chassis, or did you come up with a more clever way to hold the tin down flush? |
#7 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Pots and pans.....found at a "kitchen" outlet, they are usually made of a good looking aluminum, the really small ones of course.
Take your TXs to the store to size them up...watch how the handles are attached as you will be removing them. Next up will be how they will be mounted, there are no flanges obviously on the top (Now bottom ) of the pot....perhaps epoxy or??? _________________________________________Rick..... ... |
#8 |
The tea tins is a really clever idea. I like it.
I have a bunch of Lundahl iron for my Karna's to find covers for. The K&K ones at $36/ea are a bit too steep. |
#9 | |
I like the Twinings tea tins and have used them in the past.. Also in the USA Progesso soup cans can be made to look quite nice as well.
www.kta-hifi.net |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Transcendar Budget SE Transformers | wrenchone | Tubes / Valves | 15 | 12th April 2008 09:53 PM |
| Surprising Output from a "budget" project | musgofasa | Subwoofers | 10 | 19th March 2008 05:13 PM |
| Anyone ever tried these output transformers? | G | Tubes / Valves | 3 | 22nd September 2003 11:41 PM |
| Page generated in 0.09674 seconds (80.71% PHP - 19.29% MySQL) with 10 queries |
