Another KT-88 - Page 2 - diyAudio
Old 29th July 2008, 04:33 PM   #11
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: Another KT-88
Originally posted by cryo
................ This is my version of Michael's KT-88 single ended circuit. .............
Beautiful.................
pardon my ignorance, but please supply a diagram or link.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 29th July 2008, 04:47 PM   #12
cryo is offline cryo  United States
Sorry, I misspelled Mikael's name. I think this gif image should show the schematic I used.
Old 29th July 2008, 04:57 PM   #13
I should really thank Mikael for his schematic, it was great. And I should also thank Sherman, because I think it was his power supply design that I used. Here is the drawing for that also.
Old 30th July 2008, 01:04 AM   #14
alexg is offline alexg  Philippines
alexg's Avatar
Cryo, nice job!
I built a few of this amp using Mikael's circuit, and after finishing each one and hearing how it sounds, the sound does not fail to amaze me!
Though, I can't build it as pretty as cryo's.
Old 30th July 2008, 02:16 AM   #15
chrish is offline chrish  Australia
chrish's Avatar
Nice job.
How did you get such nice neat holes for the caps, especially the oval cross section one? I see you appear to have used some little clips to hold them in (requiring precision holes so the lip holds them in?). Did you make these yourself? looks like a better solution than can clamps.
Chris
Old 30th July 2008, 02:32 AM   #16
Sal Brisindi's Avatar
Wow, absolutely a beautiful job, I am thinking building the EL34 version of that amp as I pretty much have all the parts on hand.
Sal
Old 30th July 2008, 02:35 PM   #17
I will try and answer a few questions. Rodmunch asked how much this cost to build. Probably about $500 is my guess. The biggest expense being the James transformers and power supply. Lots of little stuff.
Chrish asked about the capacitor holes. The round ones were made with hole saws, drill very slow with a drill press and use lubricant. Now I must say that my technique worked, but I could not get the exact size hole I wanted. So I have a small mill that I used to clean up a smaller diameter hole and enlarge it to the exact size I wanted. I know a milling machine is a big expense, but a used bench top model is not much compared to what we drop in parts for these guys.
The oval hole was made with two holes that were then connected, I at first filed them. But I ended up now cleaning up the holes with the mill, and then connecting them on the milling machine. Hole saws can work very nicely, you just have to be very patient, and they would be tough to control without a drill press. I just had the small milling machine, and with 1/4" aluminum plate it machines like butter.
The hold downs for the caps are actually small cable clamps. I flattened them just a bit. After the caps were fitted into the holes, I placed the clamps where I wanted them. Holes were marked, then drilled on the drill press, and things work great.
I used countersunk flat-head bolts with a hex drive throughout. They just look nice and work great. I was going to use chrome, but they are really expensive. I found stainless was a lot cheaper, and a quick polish with a rag wheel and some polishing compound makes them look just like chrome.
Last thing was for the output tube vent holes. I tried to lay them out by hand and it was next to impossible. So I used a simple CAD program and laid them out precisely. Then I printed off the template, used a spray adhesive to attatch it to the plate in the exact position. Then I just drilled through the template and all of my holes were dead on.
Old 29th September 2008, 03:59 AM   #18
John L is offline John L  United States
John L's Avatar
Has the mistake, in Alex's rendition of Mikeal's KT88 amp been corrected yet? I was also getting ready to work on this unit, and this is the very first I have heard about there being something wrong with the diagram.
Help needed.
Old 30th September 2008, 02:10 AM   #19
John:
I'm sorry, I don't know what mistake you are referring to. Did Alex have something amiss in his own KT-88 build? I would be happy to help if possible, but am a bit confused as to the problem.
Old 30th September 2008, 02:21 AM   #20
John L's Avatar
John:
Someone mentioned this on one of the KT88 threads. It's not this one, but another. I can't remember who made it, but I think I heard it somewhere else. Maybe Porkchop, but I'm not certain. I'll try to go through and find it, ok?
Copyright 1999-2017 diyAudio
