| diyAudio Sponsor | ||
Gents,
Could some one tell me how to calculate output impedance of a Pentode amplifier that uses global negative feedback? This is easy for triode amplifiers, but since Pentodes theoretically have an infinite open loop output impedance, I'm unsure how to go about it. |
#2 | |
Hi Jeb-D.,
1) Just take the rp of the pentode (or any tube type, for that matter) at the chosen operation point by either reading it from the spec sheet (not often given there) or by deriving it yourself from the plate curves, which is easily done and precisely enough. 2) Then divide this rp by the pri:sec impedance ratio of the OPT 3) Then multiply by feedback factor (i.e 6dB = 2) 4) Donīt fall from chair when comparing Zout (and DF) of triode based and pentode based power stages ... For pure class A PP, just use 1/2 rp of a single tube for your computations. For class A/B PP or class B PP, you have to consider that the reflected impedance each tube sees when operation strays into class B softly changes from 1/2 Raa to 1/4 Raa due to cutoff of one tube of a pair during each half-cycle. So you will have to consider and recompute the actual impedance ratio the OPT gives (or more precisely, what each tube sees) for class B, which is easy enough So, for class A/B PP amps, often it is easier to really measure open loop Zout at the OPT secondary and plot against output power (and maybe frequency, too), then just apply the feedback factor - given the chosen feedback type is of reasonable linear frequency character - which it usually ainīt considering deliberately introduced time constants (like "speedup caps, etc") being involved. Regards, Tom Schlangen
If in doubt, just measure. |
#3 | |
diyAudio Moderator Emeritus
#4 | |
Tom
#5 | |
EL84 rp = ~40k Zo no feedback = 8 x 40k/4k = 80 ohm. According to your calculations Zo with 20dB (10x) NFB should be 80 ohm / 10 = 8 ohm. When measuring Zo in this simple circuit you will find it much lower, why? If you look up a classic text book you'll find that Zo is more like rp/(1+(mu x B)). It is crucial to see that this will give you another result than the normal Aol/Acl. The tricky part may be to find a good figure for mu in a pentode circuit. An approximation is to measure Aopen with no load connected to the amplifier. And of course, since Aopen =~ Rl x gm, and Rl is infinite, Aopen is much higher than Aol measured the normal way with load. Jan E Veiset
Life is hard - Then you die. |
#6 | ||
So, it seems that it is pretty much the same as triode.
Thanks! |
#7 |
B is the fraction of the signal that is fed back.
In a cathode follower B is close to 1. Jan E.
#8 | |
Now i'm thinking Pentodes mu = (gm x Rl) So that equation can work like Zo = rp/(1+((gm x Rl) x B)) Where Rl is R load (primary impedance of the OPT). |
#9 | ||
rout = 1 / (s x vu x FD) rout => output resistance of a pentode amp, anode output s => transconductance of the pentode vu => gain of the stages from input of negative feedback to the grid of the output pentode FD = Re / (Rg + re) FD => feedback divider (see post#7) re => input resistance of the stage where feedback is input Rg => feedback resistor Kind regards, Darius |
#10 |
8ohms Zo with NFB sounds about right if the pentode cathode is not bypassed.
Be sure your foil hat has a good low impedance ground. |
| low zout vs output transfo | jeapel | Tubes / Valves | 6 | 6th February 2009 05:10 PM |
| help needed: hi Zin, lo Zout, hi swing driver for experiments | aletheian | Solid State | 5 | 21st July 2008 03:28 PM |
| A small no-fuss pentode/pentode SE amp | Tubes4e4 | Tubes / Valves | 13 | 1st January 2006 05:16 AM |
| Zout adapted for 2 EL34 80W Va=560V | Davidakosa | Tubes / Valves | 2 | 29th July 2004 06:56 PM |
| Time for low Zout preamp | argo | Tubes / Valves | 40 | 11th December 2002 11:58 AM |
| Page generated in 0.07917 seconds (76.36% PHP - 23.64% MySQL) with 10 queries |
