#31 | |
#32 |
The output impedance of any amp will be quite different when it is switched off. Typically it will be higher than normal.
The damping effect of the output impedance will have little effect away from the bass resonance. As I said, it depends on whether you are actually delivering a watt or not. Anyway, do you want your amp to drive your speaker or do you want your speaker to do its own thing? I think I am right in saying that actual measurements show that SS watts equal valve watts, provided that no clipping occurs and we really are comparing like with like. Different clipping performance largely explains the persistent perception to the contrary. I am repeating myself so I will stop. |
#33 | |
| low zout vs output transfo | jeapel | Tubes / Valves | 6 | 6th February 2009 05:10 PM |
| help needed: hi Zin, lo Zout, hi swing driver for experiments | aletheian | Solid State | 5 | 21st July 2008 03:28 PM |
| A small no-fuss pentode/pentode SE amp | Tubes4e4 | Tubes / Valves | 13 | 1st January 2006 05:16 AM |
| Zout adapted for 2 EL34 80W Va=560V | Davidakosa | Tubes / Valves | 2 | 29th July 2004 06:56 PM |
| Time for low Zout preamp | argo | Tubes / Valves | 40 | 11th December 2002 11:58 AM |
