diyAudio Sponsor
Old 28th July 2008, 01:07 PM   #1
JandG is offline JandG  United States
Default Lab supply for cathode bias experiment question..
Can I use one of my lab PS's for hooking up cathode bias on some siple SE amp experiments. I am using NiMH batteries most of the time, even my Dewalt cordless drill battery from time to time,. Will the trickle charge be a bad thing for useing a adjustable lab supply for this lazy bias experiment, I just want to be able to hear differances & change output tubes on the quick ..I have know problems have many supplies for one amp I do it all the time, no small children around here. no cats etc..If I can this would be great..This would be for mostly the output tubes in SE as I allways have enough batteries for input & driver tubes.
J & G
Old 14th August 2008, 04:20 AM   #2
rubli is offline rubli  Mexico
rubli's Avatar
Send a message via MSN to rubli
I would not use such batteries batteries to bias your tubes, any discharged battery will ruin your tube, no problem in using a bench PS, rmember the bias is negative, take care in checking that the negative post is not connected to phisical ground...
regards
Alex
Old 14th August 2008, 01:37 PM   #3
O.k., so I can just do this w/ lab supply for grid bias only in - & without the Neg post physicaly grounded. NO cathode bias experiments can be done with lab supply..? I suppose not but want to check.. Thanks J & G
SE cathode bias question tubesmuggler Tubes / Valves 2 21st April 2009 07:53 PM
Question about Cathode bias in this Magnavox amp. . . Nihilist Tubes / Valves 3 21st January 2009 07:33 PM
cathode bias circuit question gary h Tubes / Valves 14 26th August 2008 12:36 AM
newbie question about 7591 cathode bias joshuahhhhhhh Tubes / Valves 3 9th December 2007 04:33 PM
Page generated in 0.07697 seconds (70.21% PHP - 29.79% MySQL) with 10 queries
