| diyAudio Sponsor | ||
The amp is a Leak(British company)Amplifier from about 1960.See Schematic.I am restoring this but when I measured the output resistance this is the readings I got.First don't the reading seem low for a output transformer and second,why is the center tap not equally resistance from the ends. I thought at first that the output transformers were bad but they are both identical.Why is't the center tap in the middle of the transformer?
#2 |
On a cheaper (less interleaved) transformer, it can simply be because the turns get longer as you get further from the core. Each side has the same number of turns, but the ones further from the bobbin are longer and thus have higher resistance.
I do not see a schematic.
Be sure your foil hat has a good low impedance ground. |
#3 |
I can't seem to upload the schematic. So you are saying that the coil is really tapped in the middle? Also isn't 100 ohms low for an output transformer.
#4 |
#5 |
http://imageshack.us/
Copy the code from the box marked "Thumbnail for forums (1)" into your post, and the picture will appear. |
#6 |
[IMG]http://[/IMG] I,m trying to upload from my computer
#7 |
hope its here now its saying the schematic is too big.
#8 |
The transformer seems perfect.
#9 |
OK thanks
#10 |
| Se output transformer question | nhuwar | Tubes / Valves | 5 | 4th March 2008 02:06 PM |
| Output Transformer Question? | Cloth Ears | Tubes / Valves | 9 | 3rd April 2007 04:37 PM |
| 1:1 output transformer question | Tyimo | Solid State | 31 | 16th January 2007 01:14 PM |
| Output Transformer Question | 316a | Tubes / Valves | 3 | 14th June 2004 02:58 PM |
| Page generated in 0.09483 seconds (74.18% PHP - 25.82% MySQL) with 11 queries |
