Output transformer Question - Page 2 - diyAudio
Old 2nd August 2008, 05:57 PM   #11
hey-Hey!!!,
That would make a nice IT. 2k CT to 600 CT is a 1.83 step-down. Or for headphones... The frequency response is a bit light( 50 to 10k cps. ), but depending on the loading you can probably reduce power and gain some there.
cheers,
Douglas
the Tnuctipun will return
Old 2nd August 2008, 08:07 PM   #12
HollowState's Avatar
My eyes see it as 9000 ohms CT. This is a mil. spec. transformer and 50-10,000 ~ is what the Government needed and wanted to see written on the part. It's been my experience with transformers like this that the bandwidth could be considerably more. Especially at less then rated power.
Victor
1944: 18 year olds storm the beach of Normandy into almost certain death.
2016: 18 year olds need a safe place because words hurt their feelings.
Old 2nd August 2008, 11:25 PM   #13
Tweeker is offline Tweeker  United States
On photographed OPT: It is for PP use, doubt it will work well SE unless in parafeed etc. Id try a pair of EL84s. Red Light District is one of many example much information can be found on.
El34s as unbypassed triodes, cathode biased might work quite well.
Be sure your foil hat has a good low impedance ground.
Old 3rd August 2008, 03:38 PM   #14
Originally posted by Tweeker
On a cheaper (less interleaved) transformer, it can simply be because the turns get longer as you get further from the core. Each side has the same number of turns, but the ones further from the bobbin are longer and thus have higher resistance.
I do not see a schematic.
It can be done to get both sides of the CT the same length( with the same turns count, and thus same resistance). It is not a function of interleaving, but of interleaving for that end. I suspect that focusing on better couplilng instead of equal resistance is a better idea. Compared to the Dynaco/Acrosound style it is easy to get closer to equal length/equal resistance halves with more complex interleave.
cheers,
Douglas
Old 3rd August 2008, 03:42 PM   #15
What I meant is if there is little to no interleaving, say a guitar opt, the difference will be quite large. Getting them the same length isnt the point, as you mentioned.
Se output transformer question nhuwar Tubes / Valves 5 4th March 2008 03:06 PM
Output Transformer Question? Cloth Ears Tubes / Valves 9 3rd April 2007 05:37 PM
1:1 output transformer question Tyimo Solid State 31 16th January 2007 02:14 PM
Output Transformer Question 316a Tubes / Valves 3 14th June 2004 03:58 PM
Copyright 1999-2017 diyAudio
