diyAudio Sponsor
Old 27th July 2008, 09:14 PM   #1
bsgd is offline bsgd  Brazil
bsgd's Avatar
Red face Fake electrolytics?
Hi all!
I just got some EPCOS 470uF/450V electrolytics.
I tried searching EPCOS website but it looks like this series number B43503 does not exist!
So, what do you guys think, fake or not?
Old 27th July 2008, 09:33 PM   #2
astouffer's Avatar
See if the specs for your cap match the physical size from EPCOS or another manufacturer. A while ago someone posted pics of some fake caps and they were physically small compared to a real one. In fact inside the small case was an even smaller cap!
Old 27th July 2008, 10:35 PM   #3
bsgd's Avatar
Hehehe I dont plan on opening mine, but I really hope there isnt a 100uF 200V cap inside it!
I'll compare the size with similar epcos caps....
Old 27th July 2008, 10:39 PM   #4
bsgd's Avatar
Apparently size is the same as a genuine 470uF/450V cap: 35mmx50mm.
The thing is these caps were pretty cheap, and to make things worse there is no mention to them anywhere on the web.
Old 27th July 2008, 11:06 PM   #5
Juergen Knoop's Avatar
usually only retail products are published.
For customs products you wouldn't find any data.
Anyway the S&M (now EPCOS) B43503 datasheet ends with 330u/450V.
Maybe your local EPCOS bureau can tell you, if this could be a custom part.
regards
Old 27th July 2008, 11:12 PM   #6
russo is offline russo  Portugal
Why you don't measure them?
Old 27th July 2008, 11:23 PM   #7
bsgd's Avatar
regards
Where did you find the B43503 datasheet? I couldnt locate it anywhere...
I got these caps from a guy that has no idea where they came from. He got a box full of them and is selling them out cheap...
Old 27th July 2008, 11:24 PM   #8
bsgd's Avatar
I can only measure for capacitance. They do measure around 430uF, but that doesnt really mean they are real EPCOS caps.
Old 27th July 2008, 11:31 PM   #9
Ty_Bower's Avatar
How many did you buy? Can you spare one to cut open?
Old 27th July 2008, 11:42 PM   #10
types table:
Old electrolytics never die, they only.... Pbassred Solid State 13 9th October 2010 12:55 PM
Inundated Electrolytics mach1 Tubes / Valves 6 24th November 2008 01:15 PM
50/47uf Electrolytics TheMooN Parts 1 8th December 2007 11:38 AM
ARC D90 needs new electrolytics Pete22 Tubes / Valves 9 3rd August 2006 11:31 PM
Electrolytics 101 Frazzled Parts 3 21st May 2004 01:49 AM
Page generated in 0.10754 seconds (79.34% PHP - 20.66% MySQL) with 11 queries
