diyAudio Sponsor
Old 27th July 2008, 03:50 PM   #1
Cobra2 is online now Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Transistor phase splitter (Yaqin MC-84L)
I noticed this Yaqin amp has a transistor for phase-splitter, is this a good solution? Unusual "modern" for a chinese amp?
http://yaqin.slickpepper.org.uk/wp-c...4l_circuit.jpg
Datasheet 2SD669:
http://www.datasheetcatalog.com/data...6/2SD669.shtml
Arne K
Ars longa, vita brevis
Old 27th July 2008, 05:01 PM   #2
I'm not enthusiastic about that design, in general.
The BJT is a "concertina" of sorts and should not do too much sonic damage. Perhaps the load is truly split. Still, non-symmetrical resistances in a "concertina" phase splitter raise doubts in my mind.
I don't like the non-symmetrical 12AX7 SRPP voltage gain block at all.
IMO, the design has a "Cheap Charlie" aroma.
Eli D.
Old 27th July 2008, 05:26 PM   #3
SY's Avatar
No kidding. And to make things worse, the SRPP uses up a potentially good section of the 12AX7 to no real advantage.
If it were my amp, I'd rewire it for a grounded cathode input stage direct coupled to a split load tube. Because of the high impedance input of the split-load, you can use a CCS on the first stage, which gives you plenty of gain to make the feedback effective. 12AX7 is a better choice than its reputation would suggest as long as the plate load is VERY high, but a 12AT7 would be my first choice there.
Given the slipshod design, you might want to examine the output transformers carefully to see if it's worth trying to polish a turd.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 28th July 2008, 01:41 AM   #4
Send a message via AIM to audiowize
It might almost be easier to just implement a simple/classic 12AT7 directly coupled cathodyne phase splitter. Of course, an amp like that might be built on a board, or have iffy output transformers as some have suggested.
Old 28th July 2008, 05:18 AM   #5
DIY !
Cobra2's Avatar
So, if I have an amp with little space, and limited filament-supply, this is still a bad option...maybe I can squeeze in one 6111 sub-mini tube (as gain-stage?).
Arne K
Old 28th July 2008, 06:46 AM   #6
You can rework this amp with one 12AT7 per channel. I think you will be ok in terms of filament supply. If you are still hurting, use a single triode and a transformer to minimize filament requirements. How about you post some shots of the inside and transformers.
Old 28th July 2008, 07:45 AM   #7
Arne K
Arne,
The Chinese design you showed SUCKS. However, there is nothing wrong (IMO) with a SS "concertina" phase splitter, to save space and filament power.
DC couple a high voltage enhancement MOSFET to the the common cathode voltage gain tube. Employ identical source and drain resistors of a value appropriate to the ID desired. If a wimpy 12AX7 or similar type is the voltage gain device, use a ZVN0545A as the splitter. Other tube types in the voltage gain "hole" can drive the reverse transfer capacitance of the IRFBC20, which is more capable than the little ZVN0545A.
Eli D.
Old 28th July 2008, 05:21 PM   #8
DIY !
Cobra2's Avatar
Thanks for the advice, - it is really for an EL34 amp.
Chinese EL34 amp to modify
I'm just looking for options, and wondered if it could be an good idea.
I left this amp on the shelf, when I ran out of parts....and now hope to get it running again. I managed to squeeze a couple of ST-70 output irons on top instead of the cut-up-Hyundai and stolen phone-wire OPT's ;-)
Arne K
B.T W.: Any more "common" mosfets I can use?
Old 26th December 2010, 10:41 AM   #9
Rockmore's Avatar
Received a MC-84L as a xmas present. It's stock. To get this thread rolling again, would like those of you interested, owning, or modding them to show exactly what and how you've done and/or what needs to be done.
Old 26th December 2010, 02:09 PM   #10
base fed from cathode end of srpp resistor is not symetrical use of triodes, but errors to the side of providing needed base current.
I dont see a problem with it.
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
Phase splitter types slideman82 Tubes / Valves 73 15th October 2009 05:09 PM
phase splitter with Tr ? sam8888ysl Tubes / Valves 9 22nd October 2008 11:28 AM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 09:48 AM
6DJ8 as phase splitter. kegger Tubes / Valves 5 21st August 2006 03:03 PM
Page generated in 0.11616 seconds (77.48% PHP - 22.52% MySQL) with 11 queries
