| diyAudio Sponsor | ||
I am a real newbie when it comes to Power Supplies and I am wondering...
Why do solid state amps have much bigger (over 10000uf) filter caps then tube amps? Also, how do you get the values/voltages of those caps when building your own? How do you design a Pi or CRC filter? Pardon my innexperience, but I am very curious and could use some help. Thanks
((AE)) |
#2 | |
The easiest way to play with power supplies is to download PSUD from http://www.duncanamps.com/psud2/index.html |
#3 |
Seconding the PSUD suggestion, it really rocks
#4 |
Is there a Mac friendly power supply designer?
Or a friendly genius?
((AE)) |
#5 | |
You need a guru to answer the most basic questions? I appreciate the coolness factor of software and the buzz of forums but nothing beats reading a basic electronics text as far as gaining knowledge is concerned. Yes, it does take some effort. |
#6 |
"On the other hand, you can learn something from almost everybody." - Charles Hansen
((AE)) |
#7 |
Seriously, this is discussed at length in any basic electronics text. Start with a classic like Horowitz and Hill. It is indeed a function of current requirements and voltage.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 | |
Free download: Rectifier Applications Handbook. Study up and become your own PS "guru". |
#9 |
#10 | |
Banned
You'll probably get more help if you take a slightly less glib attitude and show that you are putting in some work of your own by asking more educated questions. 'How do you design a Pi or CRC filter?' covers a lot of ground... w |
| Amplifier Guru's HELP | only126db | Car Audio | 7 | 30th December 2008 11:55 PM |
| One for the GURU's.... | Lostcause | Class D | 2 | 19th July 2008 11:56 PM |
| Precision Power Guru Please Help. | corradolvr | Car Audio | 13 | 9th December 2007 02:29 AM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.12973 seconds (81.02% PHP - 18.98% MySQL) with 10 queries |
