diyAudio Sponsor
Old 26th July 2008, 05:20 PM   #1
Default Direct Coupling question
Hello, I am new to direct coupling between stages. I would like to try it between my first and second stage in my amp. If I'm getting the idea right, I have to raise the voltage of my cathode until the difference between it and the plate is equal to the bias point of the grid, correct?
I was wondering if it is possible to do this with zener diodes and what are the potential benefits and drawbacks. I have linked to a schematic of what I am trying to do.
http://www.flickr.com/photos/1403176...37127/sizes/l/
Thank you.
Old 26th July 2008, 08:12 PM   #2
SY's Avatar
That will work, but injects all the noise and nonlinearity of the stacked Zeners right into the input of the second stage. You could also use a bypassed resistor in that spot, but that's just a back-door way to capacitor couple.
There are probably better topologies to use to get that second stage happy with the DC, but you may need to add another tube section or two. A cathode-coupled second stage might be an interesting alternative. When all is said and done, you'll have to figure out how to remove the DC from the output...
You might want to see if there's a copy of Landee's "Electronic Designer's Handbook" on line somewhere; there's excellent coverage of DC amplifiers.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th July 2008, 12:33 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
You don't need to bother with zeners; a resistor will do the same job if it's sized correctly. Its value should be = (cathode voltage)/(tube current).
Direct-Coupling Question sorenj07 Tubes / Valves 10 25th April 2008 06:43 AM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
direct coupling 2a3maniac Tubes / Valves 9 13th February 2004 09:36 PM
direct coupling 2a3maniac Tubes / Valves 11 2nd February 2004 07:19 PM
Direct coupling question... SHiFTY Tubes / Valves 8 3rd October 2003 09:49 PM
Page generated in 0.07505 seconds (72.98% PHP - 27.02% MySQL) with 10 queries
