diyAudio Sponsor
Old 26th July 2008, 04:55 PM   #1
ixe13 is offline ixe13  Canada
Default What's the best way to hook up an Isolation transformer
I bought an isolation transformer (http://www.hammondmfg.com/169.htm model 169G) to bring down the 120/123 AC Volt coming out the wall outlet to 115 Volts for a pair of QUAD II.
My primary concern wasn't really to isolate but rather to bring the main AC down a bit. I suspect the transfo might be bit overkilled for the job, but then, I might find other uses for this thing later on...
1-Now, at the primary, There is no indication on which wire the hot and neutral from the main outlet are connected. both wires are black. I guess it doesn't matter, but I though I better ask...
2-At the secondary it's seems obvious, 0 volt is the neutral, ...right?
3-I will put this transformer into a steel enclosure. Should I isolate the transformer itself from the enclosure using rubber washer or something similar?
4-On the picture, you can see that there is a ground connection on this Transfo. Is it the transformer's frame that provide it ?
5-And lastly, what should I do concerning the third prong(Ground) from the main and the QUAD. Could be related to the question 4...
The QUAD do have the third prong connected to their Chassis.
Thanks in advance for any advices since I wont connect this thing before knowing exactly whay I'm doing. I did do some reaserch, but ended up more confuse than anything...
Yves
Old 26th July 2008, 07:16 PM   #2
DougL is online now DougL  United States
For your application, it does not matter.
Correct. You are 2 for 2.
Yes
The safety ground should be connected to the input IEC, the output plug, the metal case and the transformer frame at a single point to prevent any ground loops.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 27th July 2008, 08:54 PM   #3
I checked the schematic and did not see the dot that normally is indicated if there was a polarity on the primary. the schematic shows both are black. so even if you wanted to differ on which is hot and which is neutral...how would this be done since they are both black...conclusion...on the primary side...it wouldn't matter.
Old 28th July 2008, 01:50 AM   #4
Send a message via AIM to audiowize
FYI - An autoformer is generally less expensive and a bit easier to wire, and I would gander a tad more efficient also.
Old 28th July 2008, 04:10 AM   #5
Sorry in advance Audiowize
- you just pushed one of my buttons.
Autoformers are in my view just "bloody" dangerous. I would be in favour of banning them entirely. The problem of course is no isolation between input and output.
Ian
Old 28th July 2008, 06:41 AM   #6
Do elaborate on your issues of not having isolation. If you're just adjusting voltages, I don't see the need for a second winding. As long as safety ground is maintained, I don't see the problem. In fact, a GFCI will trip from a problem with an autoformer, like your finger making contact. The same cannot be said for such an instance on the secondary of an iso transformer.
Old 28th July 2008, 10:44 AM   #7
I tryed a variac and the bloody thing was leaking 20 Volt AC between any of the output prong and the frame... even turned off...
Now Theory is not my strong point, but I dont think this is right.
And Ive read quite a bit about variac on different forum, and since it's a good thing in a lab, I didnt really wanna put this thing in my livingroom for all kind of reason...
Thanks for the comments
Yves
FS: Isolation Transformer Dick West Swap Meet 9 8th January 2006 07:47 PM
Transformer hook-up question to 115V AC line Joseph0 Tubes / Valves 10 19th August 2005 02:00 PM
hook-up wire/transformer questions jfk Chip Amps 0 14th April 2004 04:41 AM
Isolation Transformer HarryHaller Solid State 9 5th August 2002 12:30 PM
Page generated in 0.09615 seconds (75.76% PHP - 24.24% MySQL) with 10 queries
