| diyAudio Sponsor | ||
Hi all,
I have a quick question. Is it neccesary to have a air gap in a output transformer for a pp amp? I can understand the use of the air gap in se amps, but I've been browsing some sites and some say pp should have it and some say it shouldn't. I haven't built pp valve amps before only se.Thanks, Mielie
It's one of the best feelings in the world when you build something without it going up in smoke............ |
#2 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 | |
And here is a quick answer before the guys with the long formulas have responded. The airgap will improve linearity and allow for some unbalanced dc if the tubes are not well matched. Too much gap will decrease primary inductance. Practically all cores have some distributed gap. I have an old WE pp transformer which does not have a defined gap but all Es are on one side and all Is on the other. The core is indeed huge but it will take 60mA unbalanced without saturation. |
#4 |
Thanks, that's what i thought
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.07893 seconds (72.07% PHP - 27.93% MySQL) with 10 queries |
