diyAudio Sponsor
Old 23rd July 2008, 10:03 PM   #1
Zap is offline Zap  United States
Default Transformer questions / Good headphones?
Moving through the planning stages of building a DC Darling amplifier I'm considering that I may now use it for headphones at least part of the time.
I'm curious to know if anyone can suggest high quality, high fidelity headphones for comfortable listening and extended wear throughout the workday.
Additionally, I want to lay the OPT issue to rest. I've seen some frequency response plots specifically for the Darling showing that when a set of Hammond transformers were replaced with Lundahl the frequency response plots changed in a dramatic way.
Transformer Plots
I'm concerned with this being a problem since I'd rather spend a bit extra if the amp will excel and sound good when hooked up to efficient speakers. What confuses me is the rather low output power, yet rolloff is still seen anyway. Does the core just saturate quickly, or is it undersized?
Given this problem, how does one go about assessing the performance of a transformer without having to buy tons of them to make an informed decision? Obviously the Transcendar transformers on eBay aren't too expensive and may weigh a bit more than the $20 Edcors. I like the way the CXSE Edcor's sound that I have in my Simple SE. I just don't want to over/under spend or size the units so they are heavier than needed.
Thanks!
Old 24th July 2008, 01:12 AM   #2
kevinkr's Avatar
Grado headphones, many models and price points.. Great sound and very comfortable for long term use.
Talk to Jack Elliano at Electra-Print about transformers for your "headphone" amplifier. He has done transformers for Doug, (dsavitsk) and me as well. I think they're really good and I'm sure Doug will concur.
www.kta-hifi.net
Old 24th July 2008, 01:36 AM   #3
TerryO is offline TerryO  United States
TerryO's Avatar
I personally like my Sennheiser 580's, no longer the top model but they are none-the-less very musical and non-fatiguing. I had the Senn 414's (I think it was) years ago and they were excellent as well, very light weight and confortable.
I'm no expert on Transformers, but one that was, the late John Wyckoff thought that Jack Elliano's Transformers were about as good as it gets.
Another one that there have been talked about by those "in the know" is O-netic's Bud Purvine. He's also the creator behind the enable cone treatment.
I'd certainly contact both of these people if I was looking for top notch Iron.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 24th July 2008, 02:17 AM   #4
dsavitsk's Avatar
Originally posted by kevinkr
Grado headphones,
I concur on both points. These are both built with E-Ps.
http://www.ecp.cc/SSS.html
http://www.ecp.cc/less-pressivo-plus.html
I'll also add that AVCs and TVCs used on the output as parafeed transformers with very low mu tubes and bypassing the volume pot is another good solution.
http://www.ecp.cc/less-pressivo-plus-plus.html
http://www.ecpaudio.com
ESL transformer questions mjon Planars & Exotics 7 21st June 2008 05:12 PM
transformer questions woodturner-fran Tubes / Valves 9 12th March 2007 09:09 PM
Transformer Coupling and Headphones? (Toob Noob) GD3 Tubes / Valves 10 20th May 2006 11:30 AM
Questions about JLH for headphones Nisbeth Solid State 9 19th July 2005 06:50 PM
Transformer questions Trout Tubes / Valves 3 1st February 2005 01:19 PM
Page generated in 0.09158 seconds (74.54% PHP - 25.46% MySQL) with 10 queries
