diyAudio Sponsor
Old 23rd July 2008, 05:19 AM   #1
jlw is offline jlw  United States
Default Counterpoint SA5000 schematic
Greetings, Just wondering if any fellow DIYAudio member has a spare Counterpoint SA5000 schematic to share.
Thanks in advance.
Old 23rd July 2008, 05:34 AM   #2
KBK is offline KBK  Canada
The 5.1 is available via a web search, and is quite similar. Enough so one might troubleshoot a 5000 via it.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 23rd July 2008, 06:06 AM   #3
Default Thanks
Thanks KBK, if the SA5000 is the natural progression (pun intended) of the 5.1 then it looks like the 5000 is a parallel 6922
plate-driving a solid state follower.
If I were to keep the solid state follower is there any
"premium grade" ones I should swap it out with or is
it pretty much hopeless?
Thanks again.
Counterpoint SA-7 Schematic PeterBGood Tubes / Valves 28 27th December 2010 10:19 PM
Do anyone has schematic for Counterpoint SA3000 ? micarlton Tubes / Valves 0 27th August 2008 12:24 AM
Counterpoint SA 3 schematic ozdiyer Tubes / Valves 2 15th December 2007 10:55 PM
Schematic Counterpoint SA3.1 and SA-9 Gydotron Tubes / Valves 3 19th December 2005 12:38 PM
Asking for Counterpoint SA-20 Schematic vr2zed Solid State 0 21st October 2004 10:37 AM
Page generated in 0.06935 seconds (69.29% PHP - 30.71% MySQL) with 10 queries
