| diyAudio Sponsor | ||
Hi, can anyone tell me how to change the deemphasis for FM100. I got the FM tuner from US and will use in Hong Kong. I need to change the deemphasis from 75u to 50u.
#2 |
You need to find the two deemphasis capacitors around the stereo multiplex decoder IC. They are in the order of a few nanofarads. Change them to 2/3 of their original value (e.g from 2.2nF to 1.5nF; these are typical values).
#3 |
FM-100 is a vacuum tube tuner and has no stereo decoder IC..
Is it a FM-100 or a 100B? www.vintagemanuals.com has manuals for several versions of this tuner.. Changing a pair of capacitors after the multiplex demodulator stage and before the output amplifier is all that is needed. I am sketchy on the details as it has been a while since I last worked on one. Very nice sounding tuner, better RF performance than the FM-50B (I have one) and less complexity than the FM-200..
www.kta-hifi.net |
#4 |
Thanks for your reply. I have the schematic for FM1000. Which cap should I change?
#5 |
Change C225 and C226.. Can't make out the values, but they should be approximately 2/3 of the existing values...
www.kta-hifi.net |
#6 |
The FM100B multiplex section is the same as the FM1000.
I also have a FM100B and FM200B. I think the FM200B have a better reception, but soundwise, both are very good and for my peference, I prefer them to the McIntosh tuners. I would also like to change the deemphasis, if possible. Raymond |
#7 | ||
See above
www.kta-hifi.net |
#8 |
Thanks! Kevin,
The value is 2200uuf. I will replace it with 1500uuf. Derek |
#9 | |
That should work fine..
www.kta-hifi.net |
| Changing a deemphasis from 50 uS to 75 uS | legarem | Analogue Source | 13 | 12th March 2010 05:51 PM |
| Fisher xp 7b | marktd | Multi-Way | 2 | 17th October 2007 12:51 PM |
| Deemphasis computer software? | Agent327 | Everything Else | 3 | 5th September 2007 08:47 PM |
| Rogers Panthera (T75) deemphasis | legarem | Analogue Source | 0 | 3rd July 2007 02:37 AM |
| fm deemphasis? | peace brainerd | Solid State | 3 | 6th March 2006 04:41 PM |
| Page generated in 0.09531 seconds (74.73% PHP - 25.27% MySQL) with 11 queries |
