Custom OT for 6C33C tube - any advice
Old 21st July 2008, 09:03 PM   #1
GlidingDutchman is offline GlidingDutchman  South Africa
Default Custom OT for 6C33C tube - any advice
I am working on an amplifier prototype that I got from a friend. It is fitted with Hammond OT's that restrict the power to only 11 watts. Apparently with the correct OT one can get 18 watts from a single 6C33C tube...?
What would the figuers be that I must supply when I have a set of custom OTs made?
Something like this:
Primary impedance: 600 Ohms
Secondary impedance: 0-4-8 Ohms
Frequency range: 15 - 50K Hz
Output: 20W
DC current: 400mA (??)
Air gap ??
Old 21st July 2008, 11:01 PM   #2
astouffer is offline astouffer  United States
astouffer's Avatar
Several companies make transformers just for the 6C33 tube. The James JS-6130H should be what you are looking for.
http://www.octave-electronics.com/Parts/james.shtml
Old 22nd July 2008, 07:47 AM   #3
ulibub is offline ulibub  France
just have a look here:
Experience Electronics
I have used their transformers for several projects and I can confirm their very high quality...
Custom OT for 6C33C tube - any adviceHide this!Advertise here!
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Tube Store in Washington DC (6C33C Triode Buy Where??) GlidingDutchman Tubes / Valves 14 6th August 2008 12:47 PM
6C33C tube stamp sphinx Tubes / Valves 4 6th January 2008 02:04 AM
6C33C-EB / 6C33C-EV extended life ? ger56 Tubes / Valves 2 14th October 2007 05:54 PM
6c33c Tube preamp lawbadman Tubes / Valves 9 26th March 2006 05:51 AM
