diyAudio Sponsor
Old 21st July 2008, 01:24 PM   #1
Default RCA tube rectifier
My Fender Champ came with a RCA agx GZ tube rectifier instead of a stock 5Y3GT. RCA agx GZ is written on the foot of the tube. There is no more information (it's a black plate). Not on the foot, nor on the glass.
What kind of tube is this. My amp is running ok with it.
Old 21st July 2008, 02:09 PM   #2
Frank Berry's Avatar
The tube may be a GZ34 (5AR4).
Frank
Old 21st July 2008, 02:33 PM   #3
Tom Bavis's Avatar
RCA generally marked the glass above the key in the base. Try breathing on the tube there and look at that area. Usually it's in an octagon.
Old 21st July 2008, 07:40 PM   #4
whitelabrat's Avatar
agx GZ sounds like a manufacturing code and not the tube type. Mr. Bavis is correct where the tube type is usually printed on the glass. It's not unusual for it to rub off, so you may have to look carefully under good lighting to find the markings. If they're missing just look for pictures of RCA 5Y3GT's, 5U4G, and 5AR4 to compare to. Ebay is a good source of photos.
Old 22nd July 2008, 02:19 AM   #5
DHT112A is offline DHT112A  United States
What I have found to work quite often is to put the tube in the freezer. Ice may form differently where the number is making it visible. You still have to look closely.
4v for rectifier tube camotecue Tubes / Valves 10 20th May 2008 09:20 PM
Tube rectifier help Cobra2 Tubes / Valves 12 3rd March 2007 01:58 PM
Z2b tube rectifier bee696 Tubes / Valves 3 4th November 2006 02:45 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Tube rectifier for VDIGC tube psu ebijma Chip Amps 2 11th March 2004 04:02 PM
Page generated in 0.08491 seconds (72.45% PHP - 27.55% MySQL) with 10 queries
