Building a Aikido preamplifier - Page 51 - diyAudio
Old 21st December 2011, 10:51 AM   #501
pidigi is offline pidigi  Italy
Originally Posted by TigerScent View Post
....you are looking at the 'Type II'...., which does have 100K unbalanced, .....however, .... mine is the 'Type I'..., which has 1K unbalanced. How do I know? I was directly informed by the designer himself.
being so close to the designer, please ask him why only 1k
Ciao
Old 21st December 2011, 04:11 PM   #502
Renron is offline Renron  United States
Renron's Avatar
I'm running my Akido pre with 4 6SN7 via tube rectifier, into a Pass F5 driving my Small Thor 4 Ohm speakers. Plenty of gain and superb clarity. No microphony (sp?) 2 feet from speaker! What's the problem again?
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 22nd December 2011, 05:36 PM   #503
rajucc is offline rajucc  India
Originally Posted by s2kov View Post
Nice work Rene!
GREAT WORK
Old 1st January 2012, 10:50 AM   #504
so does anyone have any idea of how to effectively modify the Aikido linestage for <10ohm output impedance??
Old 1st January 2012, 10:54 AM   #505
Ok, I have to ask Why less than 10 ohm?
Old 1st January 2012, 11:27 AM   #506
Shoog's Avatar
Output transformer would be the only way.
Shoog
Old 1st January 2012, 05:18 PM   #507
Ran across an article on using a 6U10 compactron 3 triode tube for an Aikido line stage. Has anyone tried this?
Old 1st January 2012, 05:21 PM   #508
john65b is offline john65b  United States
john65b's Avatar
Isn't a fourth triode needed for the Aikido?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 1st January 2012, 06:06 PM   #509
Schematic of Aikido line stage that you could use the 6U10 on.
There is a high gain section #2 in the 6U10 which could be used as the input tube once plate resistor and cathode resistor values were changed. Sections 1 and three would be used in place of the 12AU7.
Old 1st January 2012, 09:44 PM   #510
...its because the SS amp I am intending to use with it, has an unbalanced input rating of 1K ohm, so for optimal performance, using 100/1 ratio, under 10 ohms would extract most performance...., according to the designer whom I emailed about this...
Use 9 pin Aikido PCB kit or buy 8 pin ? Renron Tubes / Valves 6 25th November 2007 04:52 PM
Copyright 1999-2017 diyAudio
