Building a Aikido preamplifier
Old 24th September 2008, 04:49 PM   #21
ollebolle is offline ollebolle  Sweden
ollebolle's Avatar
This is good news
The total current will be: (5+5mA for 6N1P and 20+20mA for 5687) Total around 50mA!
50mA is within the limits for my choke
The 5687 will draw about 20mA with my B+ at 220V
Now I know how to read the table
Thank you all for the good help!
Old 24th September 2008, 05:57 PM   #22
woodturner-fran is offline woodturner-fran  Ireland
What happened me was during my build of SYs red district EL84 amp. I was using one of those transformers for the B+ - the heaters and a second B+ were coming off a different Tx.
What was happening was that the voltages were all over the place. I'd hook up one of the transfomers and get the right voltage, attach it to the circuit and it would be way off. Really difficult thing for someone inexperienced to figure. Anyway, thanks to shoog - he copped it right away. Once I replaced it the thing worked pretty ok. I think it was saturation or overloading or something (even though the current draw was very small - 10mA or something).
The ones I bought were supposedly pulls from working equipment - and in fairness the seller sent me 2 more to replace the first 2 ones which were bad - but they were bad too.....
I only mentioned it when I saw your pic of the Tx and thought oh oh! Look yours may be AOK.
To be honest I would like to hear a high voltage aikido as both of mine are the 24V type with 6GM8. These sound really good and yes, they have been put up against some really good gear and with a variety of experienced ears too.
If the worst comes to the worst, you might be able to get a 9V Tx and rectify and drop the voltage and run the heaters off that and a simple isolation transformer for the B+ - the one from a junked PC power supply might just do the trick. Ususally bathroom strip lights (ones with a shaver socket) have 20VA isolation transformers that could be pressed into service too. Not the highest quality, but they would allow you to get the thing working until you found something better.
Good luck with the build!
Fran.
ps somehow snag yourself a nice cap for the output position - a nice PIO or blackgate etc would be nice there.
Old 24th September 2008, 06:10 PM   #23
Stixx is offline Stixx  Germany
Stixx's Avatar
Or try some NOS ERO KP caps...
they are getting expensive (at least in Germany), but are worth every penny (well, cent nowadays... )
Old 24th September 2008, 07:15 PM   #24
ollebolle's Avatar
Thanks for the advice!
Old 24th September 2008, 07:22 PM   #25
ollebolle's Avatar
Originally posted by Brit01
Hi guys,
I'm just about to order the Aikido Stereo 9-pin kit from JB.
I'm a total newbie.
I was donated 4 6N1P valves from a very kind member from Netherlands.
I will probably have to have a transformer built by a local tech here. I live in Uruguay so very little available. My girlfriend will be in USA in Oct so I am getting her to bring the kit and parts back from JB.
Exactly what kind of transformer do I need to have built. I understand I need the 6.3 V DC supply for the 6N1P. We have 230 V here.
Also do I need to order the following from the kit?
'Supporting and power supply caps'.
I'm also getting hold of the power supply board from another member.
Many thanks
Chris
Hi Chris!
John Broskie offers boards for both octal tubes, and 9-pin!
6N1P is a 9-pin tube. Choose boards for 9-pin tubes if you use 6N1P
About the power transformer: Some transformers can be wired for both 110V and 220V
This might be good choice if you want to use it in both 110 and 220V countries!
On the secondary you will need a 6,3V winding for the heater. One 6N1P draws 0.6A. Four of them = 2,4A
Choose a transformer that can deliver some more current! 4A or more should be good i think...
Then you need a winding for the anode voltage!
Some transformers are center-tapped, some are not!
The power supply circuit (and board) decides which power transformer you need!
How is it designed?
Old 24th September 2008, 07:50 PM   #26
Brit01 is offline Brit01  United Kingdom
Great info. Thanks Olle.
I will hopefully be getting hold of the psu by Bas Horneman designed for the Aikido Line stage.
I believe it is like the one here:
http://www.diyaudio.com/forums/showt...&pagenumber=11
I will have to confirm once I receive it.
Old 24th September 2008, 08:09 PM   #27
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
What I would suggest is something like 250V secondary with say 150mA current.
And as ollebolle says "Choose a transformer that can deliver some more current! 4A or more should be good i think... " for the 6,3V
Since the voltage in Uruguay is the same as in Europe...specify a 230VAC primary. So that you can use it in the UK as well if you ever move back there.
If you can see the speaker cone move...it's not hifi.
Old 24th September 2008, 08:17 PM   #28
ollebolle's Avatar
Yes, I agree
And do not exceed the max rating in the datasheet
Maximum 250V for 6N1P
Higher voltage will shorten the life of your tube.
Old 24th September 2008, 08:26 PM   #29
Well in this case (Aikido) each 6N1P will see roughly half the b+ so a b+ of 300V is fine.
Old 24th September 2008, 08:33 PM   #30
Hi Bas,
Thks for jumping in.
I didn't want to bombard you with questions to your personal email.
So I need a transformer: 230 VAC input(primary) with 2 outputs, one of 6.3V DC with 4 amps and the second output with 250V DC with 150 mA?
The anode voltage is the B+ voltage?
Sorry as you can see I have a lot to study but very little time at the moment.
Building a Aikido preamplifierHide this!Advertise here!
Use 9 pin Aikido PCB kit or buy 8 pin ? Renron Tubes / Valves 6 25th November 2007 04:52 PM
