diyAudio Sponsor
Old 18th July 2008, 09:56 PM   #1
Gunny is offline Gunny  United States
Default Question about Low Impedence Filters on a Bogen PA Head Need Info.
OK I was told by some one who I got that Bogen MX60 from that IF I take out the Low impedence filter that plugs in for each mic input it will change the circuit from Low Impedence to High Impedence. True or False? I do not want to unplug one of those filters and find out it will cause issues with the amp. Three of the filters look like short metal tubes that are rounded on top the other looks like a metal cap can. If this was the case then I could hook up a quarter inch jack for a guitar input with out getting a low to high impedence adapter and a female to female plug to hook it all up since Bogen had the brainstorm of using a male 3 prong input instead of a female one.
Old 19th July 2008, 12:57 AM   #2
I made a mistake they are low impedence transformers not filters.
Old 19th July 2008, 01:25 AM   #3
Tom Bavis's Avatar
You need to replace the transformer with a jumper plug for high impedance. I don't have the MX-60 schematic, but I assume its the same transformers as the MX-30. You need a 9 pin octal plug and it has pins 2-5 and 8-9 are jumpered together.
Old 19th July 2008, 01:54 AM   #4
Tom, Thanks for the info. I never seen a 9 pin octal size base before so what were they used for besides these transformers?
Old 19th July 2008, 02:01 AM   #5
Pedal board connectors in Wurlitzer 4500 electronic organs. Do I win the useless trivia prize?
mike - www.keepingsundayspecial.org
Old 19th July 2008, 02:05 AM   #6
Tom Bavis's Avatar
I probably have a few of those plugs - email tbavis(at)rochester(dot)rr(dot)com
Old 19th July 2008, 04:04 AM   #7
Email sent Tom.
mashaffer I would have never known that.
Old 19th July 2008, 04:59 AM   #8
Speaking of the transformer cans is there a trick to removing them? They seem sort of solid yet I know they are supposed to come out.
Old 19th July 2008, 04:04 PM   #9
Never mind on the pulling the transformer can out It came out it just took a bit more pull than a normal tube does.
Bogen D070 Amp - HELP w/ INFO. Wharf_Creek Tubes / Valves 0 17th February 2009 03:54 PM
need info on how to convert my bogen k10 for guitars use tim614 Tubes / Valves 4 5th September 2008 04:42 AM
Circuits / Info on Tracking Notch Filters JohnW Solid State 3 6th July 2004 01:55 PM
xovers, impedence compensation, notch filters, baffle step, confusion? speekergeek Multi-Way 6 8th December 2003 03:46 AM
Page generated in 0.09631 seconds (75.03% PHP - 24.97% MySQL) with 10 queries
