Horz Sweep amp Pent or screen drive
Old 19th July 2008, 06:01 PM   #21
kenpeter is offline kenpeter  United States
Fixed?
Old 20th July 2008, 12:15 AM   #22
Pentode mode (yet still wrapped in a 4th circuit Triode loop).
Emitter resistor for Nervous Nellies (including me). Though plate
coupled DC back through the 4th circuit makes thermal runaway
seem an unlikely thing to be worrying...
If you were to add a switch to defeat 4th circuit plate feedback
back to that first triode. (Perhaps to better hear the Pentode)
you will be glad the emitter resistor was there!
If you needed A2, you'd have to tie the grids higher than ground.
And to a reference that can sink some current. There is no lack
of pull down current available from the BJT beneath the cascode.
Same rule applies for the previous schematic in A2 Triode mode...
I'm not gonna get around to filling in component values any time
soon. I am sorta burned out on schematics for today.
Horz Sweep amp Pent or screen driveHide this!Advertise here!
Proposed screen-drive amp design... comments, please? GordonW Tubes / Valves 37 15th April 2012 12:31 PM
Screen drive and other P-P experiments Tubelab_com Tubes / Valves 23 6th July 2010 06:08 PM
Screen Drive Push Pull ideas whitelabrat Tubes / Valves 62 26th May 2010 03:35 PM
UltraLinear Screen Drive TheGimp Tubes / Valves 5 21st August 2009 02:48 AM
Toroidal output transformers with screen drive- why not? GordonW Tubes / Valves 7 6th May 2008 09:29 AM
Copyright ©1999-2017 diyAudio
