diyAudio Sponsor
Old 13th July 2008, 05:50 PM   #1
bst is offline bst  United States
bst's Avatar
Default UHF tubes for audio?
I've been accumulating tubes at an alarming rate -- according to wife, anyway. (Last count was somewhere north of 6000...) I've found it easy and inexpensive to work with 'oddball' heater voltages and compactrons. However, I haven't tried using any of the dozens of UHF triodes and pentodes in my collection.
I've read that these are unusable due to their tendency to oscillate at the drop of a hat. But I've also read some glowing reviews of commercial amps which use them in their designs. Can anyone shed some light on this seeming contradiction?
Old 13th July 2008, 06:11 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Yes, they can be awkward and need careful attention to layout, but they repay that effort. Go for it!
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 13th July 2008, 06:13 PM   #3
Hi there,
well, a grid stopper, and often an anode stopper helps taming oscillations.
some of these vhf tubes are very good!
me thinks you must build a few amps ;-)
Michael
Old 13th July 2008, 09:15 PM   #4
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Hello from Japan,
One of my friend told me that he got good result of sonic by 5894pp with the same screen grid voltage to that of plate. He said 5894 is better sonic than 829B.
Old 14th July 2008, 06:03 AM   #5
Geek's Avatar
V/UHF tubes can be quite spectacular for audio
There's gold in them thar mountains of TV t00bz
Cheers!
Old 14th July 2008, 08:57 PM   #6
Miles Prower's Avatar
Default Re: UHF tubes for audio?
Originally posted by bst
However, I haven't tried using any of the dozens of UHF triodes and pentodes in my collection. I've read that these are unusable due to their tendency to oscillate at the drop of a hat. But I've also read some glowing reviews of commercial amps which use them in their designs. Can anyone shed some light on this seeming contradiction?
There is nothing to this at all. Remember, VTs aren't like solid state, particularly BJTs, which are at their best at DC, and it's downhill from there. Any VT, even if it's strictly an "audio" type will operate into the bottom of the VHF band, at least.
As for RF oscillation when using VHF/UHF types, it's no worse than any other type. Just pay attention to layout, and include grid stoppers as needed. The main danger for RF oscillation is high gain. Thus, pentodes and cascodes require a bit more attention to detail. Install your bypass capacitors across the socket with the outside foil grounded so that it does double duty as an electrostatic shield. If you have sockets with a central metal pin, be sure to ground it as well. It's included as a shield. Keep your wiring as short and direct as possible. Use the same type of construction techniques that would use if wiring an actual RF circuit. I did a design that used cascoded 6BQ7As (a type good to 300MHz) and had no RF problems that a grid stopper couldn't fix.
If you can make a stable transistor circuit, a stable VT circuit is easy.
Some of these UHF types, particularly the 6GK5, have pretty good audio linearity, and make some excellent voltage amplifiers, either SE or LTP. The ones I used, 6BQ7A, doesn't list any possibility for audio in the spec sheet, but they do work just great as cascoded LTP splitter/amplifiers. Take a look at the plate characteristics, draw some loadlines, and see what you get. Don't discount those TeeVee T00bz automatically.
Let the audiophoolz pay audiophool ridiculous prices for magical tubes. Remember:
As one tube becomes popular, i.e. expensive, we'll use something else. Because we can.
-- Fred Nachbaur
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 15th July 2008, 03:44 AM   #7
EC8010's Avatar
Well said, Miles.
Old 17th July 2008, 01:46 AM   #8
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
I have a friend who has a stash of about 100pcs of 954 acorn pentode tubes, anybody done anything with those?
7-pin miniature tubes for audio? phn Tubes / Valves 86 10th March 2009 11:07 AM
audio mixer with tubes? unsolved Tubes / Valves 3 27th January 2009 09:48 PM
Near RF/audio tubes sakis Swap Meet 3 25th November 2007 04:14 PM
Need advice on Val Audio amp with EL-34 Tubes FSHZ:42 Tubes / Valves 49 6th October 2007 08:20 AM
When car audio & tubes collide... Glowbug Tubes / Valves 1 15th September 2006 10:55 PM
Page generated in 0.09417 seconds (79.13% PHP - 20.87% MySQL) with 10 queries
