diyAudio Sponsor
Old 13th July 2008, 01:15 AM   #1
Zap is offline Zap  United States
Default Keeping cost down?
As I'm looking into building another amp I keep asking how some of you are able to build for so little money. I've seen numbers thrown around and can't believe how much I keep thinking I need to spend.
For instance, I am thinking about building a Darling - I'd be curious to know how much everyone else has spent on theirs. The tubes aren't that bad, and a pair of Edcor OPTs is only $40. The problem I'm having is finding a reasonably priced power transformer, chassis, sockets, switches, etc.
I swear I've seen people post that they've built one of these for under $100. How?
At any rate, good sources for parts and cost cutting (without quality cutting) tips are most appreciated.
Old 13th July 2008, 01:58 AM   #2
aletheian's Avatar
Well, the tranny swill be the expensive part, but you could shave off the cost of a few parts if you run one of the DC-coupled versions, a few more if you go to LED bias for the input stage, and a few more if you use solid state rectification and CRC filtering. The cost of tubes notwithstanding, with the Edcor trannys and a cheap Hammond power tranny, I could see that happening for somewhere around $100 if you hit up Home Depot for the chassis parts.
Heghlu'meH QaQ jajvam!
Old 13th July 2008, 02:39 AM   #3
You can use pieces of scrap lumber for the front, back and sides of the chassis, and get a suitably sized peice of aluminum, stainless steel or copper for the top from a metal supply house or scrap dealer, or as I've done a few times, you can use aftermarket automotive body panels, just try and get flat ones.
Give a man a fish and he'll eat for a day. Teach him to fish, and he'll sit in a boat all day long drinking beer.
Old 13th July 2008, 03:29 AM   #4
diyAudio Moderator Emeritus
ray_moth's Avatar
Great idea, never thought of that!
You can also save a bit by not using expensive 'boutique' resistors and capacitors, except in places where they really make a difference.
Old 13th July 2008, 03:47 AM   #5
HollowState's Avatar
Default Re: Keeping cost down?
Hamfest fleamarkets, hamfest fleamarkets and more hamfest fleamarkets. Plus electronic surplus stores wherever you can find them. That's what I've been doing for decades. You have to get up a 4 AM and be there by 6 AM at the latest. Go in as a seller if you must. (even if you don't sell) Then walk around and around for hours looking for treasure. Yes it's work, but that's how it's done. They're listed on line or in ham radio magazines.
Well, gotta hit the sack now because I'm getting up early tomorrow for one.
"The human race is just a chemical scum on a moderate-sized planet orbiting round a very average star in the outer suburb of one among a hundred billion galaxies." ~Stephen Hawking
Old 13th July 2008, 04:02 AM   #6
Send a message via AIM to audiowize
If you want to build a cheap Darling, use the cheap iron (Edcor outputs, Allied branded power transformer), and build the thing on a $10 cake pan for a chassis. Unfortunately, I end up spending about $800 per chassis on the newer stuff I've been building, so that can really kick the price up.
-Paul
Old 13th July 2008, 11:33 PM   #7
Notice I mentioned AFTERMARKET, as your neighboUrs might not like waking up and finding a gaping hole in the hood, doors, roof or trunklid of their vehicle....
Old 14th July 2008, 03:56 AM   #8
Sal Brisindi's Avatar
I built mine with all new parts for about $125 if I remember correctly.
Regards.
Sal
Keeping the workspace neat jackinnj Equipment & Tools 34 22nd March 2010 02:31 PM
Is this capacitor worth keeping? cadbury8 Parts 15 4th July 2007 04:44 PM
Has anyone been keeping up on the 'New Sensor' Controversy? aletheian Tubes / Valves 19 21st December 2005 11:17 PM
Keeping components close? Christian Solid State 3 10th October 2002 05:02 PM
Page generated in 0.09230 seconds (85.76% PHP - 14.24% MySQL) with 10 queries
