diyAudio Sponsor
Old 11th July 2008, 04:41 PM   #1
pwgtang is offline pwgtang  Armenia
Default SRPP circuit question
Question: for a srpp circuit if the the top triode cathode use LEDs
for bias instead of resistor,can we still call it srpp?Thanks.
Paul
Old 11th July 2008, 04:56 PM   #2
kevinkr's Avatar
Default Re: SRPP circuit question
Paul
While it will work from a dc perspective from the ac perspective the grid and cathode of the upper tube are virtually shorted together by the led's low dynamic impedance. I suspect it would not work too well.
www.kta-hifi.net
Old 11th July 2008, 04:57 PM   #3
Paul
In this case the bottom triode has ri of the top triode as a load.
In the srpp it has Rk x µ + ri. This should be much higher.
ri = internal dynamic resistance of the (top) triode
Rk = cathode resistor
µ value of the top triode
Kind regards,
Darius
Old 11th July 2008, 05:45 PM   #4
kevinkr's Avatar
Default Re: Re: SRPP circuit question
Kind regards,
Darius
I.E. The plate of the lower triode is looking directly into the cathode of the upper tube in series with the small dynamic resistance of the led, not a good load.. Pretty close to a short. (low impedance)
www.kta-hifi.net
Old 11th July 2008, 06:58 PM   #5
Default srpp circuit question
I am asked because I had build a preamp used 6AQ5 tubes looks
like Moebins 6AQ5 line preamp, I am not to happy with the distortion,about 0.25 at 3vrms output 1khz,I try to replaced the top resistor with LEDs and the distortion drop to 0.05 and the output V drop 1.5db.Frequency response and inpedence about
the same.This preamp only had 3.2 times gain.
Old 11th July 2008, 07:32 PM   #6
kevinkr's Avatar
Default Re: srpp circuit question
Schematics would help as well as other details, perhaps you need a lot more B+ and/or different operating point.
www.kta-hifi.net
Old 11th July 2008, 11:18 PM   #7
Mœbius is a Poindexter design. The schematic is here.
Poindexter's home page is here.
Eli D.
Old 12th July 2008, 01:29 AM   #8
That is it. The 82R replaced by LEDs.
Old 12th July 2008, 02:32 AM   #9
Look, this is a technical question about accessing the circuits posted on this thread. I have the parts and intend building an SSRP circuit. I am interested in any modifications people come up with but when I download the circuit Eli put up in Post#7 I find I can't read it properly, some of the lines are missing. This happens often. So how can I download it and then expand it to make it readable? I'm sure my 2Oyr old daughter can fix it but she's in Paris this week.............and I'm not!
Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 12th July 2008, 03:31 AM   #10
diyAudio Moderator Emeritus
ray_moth's Avatar
What I do is hover the mouse pointer over the diagram and eventually an 'expand' box appears in the bottom right-hand corner. I click on that and the diagram expands to its full size.
Aleph circuit is Single, SEPP ,SRPP or other ? SkyChu Pass Labs 8 18th June 2011 03:38 PM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 05:21 PM
CF and SRPP in one circuit . . rick57 Tubes / Valves 5 21st May 2006 11:58 PM
SRPP question Higo Tubes / Valves 3 7th August 2002 12:42 PM
I-V circuit question tiroth Digital Source 4 18th February 2002 01:40 PM
Page generated in 0.10238 seconds (82.09% PHP - 17.91% MySQL) with 10 queries
