diyAudio Sponsor
Old 11th July 2008, 02:22 AM   #1
Default old style anode/grid caps
Does anyone know where to get old style anode/grid caps? I have some from an old radio but they are too big. I need 1/4". Anything I have found looks very "modern" and these three amps (Left Right and Sub) are kinda old style mad scientist themed.
Also does anyone know how they used to connect the wires to the anode pins on the top of the 829b? I've seen several DIY solutions but none have the right look. My idea requires fabrication on my part...
Old 11th July 2008, 02:56 AM   #2
wrenchone's Avatar
Molex Mini-Fit Jr. female contacts work well for the business part of the interface to the plate pins of the 829B and 3E29.. They are available in both tin and gold plating, depending on how deep your pockets are. If you're lazy, just trash the motherboard connector on any junked PC power supply (ATX and newer), and you'll have a bunch of mini-fit female contacts already crimped to wires. Once you have the business part, what you surround it with is entirely up to you. Appropriately colored heat shrink is quick and unobtrusive (it's what I plan to use).
plain Big caps on psu vs. carlosfm style Snubber shiraz Chip Amps 25 9th September 2008 03:11 PM
E1148,CV6-How do you distinguish the anode/grid caps? protos Tubes / Valves 1 6th February 2008 04:47 PM
Anode Cap Question sgerus Tubes / Valves 6 7th September 2007 05:00 PM
Coupling caps size with grid choke? DHT112A Tubes / Valves 4 7th December 2006 05:22 PM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 01:59 AM
Page generated in 0.06079 seconds (70.83% PHP - 29.17% MySQL) with 10 queries
