diyAudio Sponsor
Old 10th July 2008, 08:16 PM   #1
Default 6H30 Dual Triode
Hi there
Searched the net etc - where can I find a propper datasheet for the 6H30 dual triode tube?
Thank you.
D
Old 10th July 2008, 09:01 PM   #2
does the tube go by any other names? is the H a Russian character? Post a pic of the tube.
Old 10th July 2008, 09:20 PM   #3
Well
I'll report back tomorrow - tube is in the workshoppe atm.
It is two new tubes. Marked as 6H30 followed by Russian characters. Made by SOVTEK in Russia. Tall glass envelope.
Used to drive a single 6C33C power tube.
D
Old 10th July 2008, 09:26 PM   #4
This site has a lot data on russian tubes including the one you
want. Look under devices and then click the tube you need.
They have a line stage using this tube also.
I did not know how to save the whole data page but here is
part of it.
Old 10th July 2008, 09:27 PM   #5
And here is the line stage using it.
Old 10th July 2008, 09:29 PM   #6
analog_sa's Avatar
http://www.triodeel.com/6h30.html
http://lib.store.yahoo.net/lib/thetu.../RU-6H30DR.jpg
Old 10th July 2008, 09:45 PM   #7
jane is offline jane  Norway
jane's Avatar
Here are some free software for 6H30:
http://www.glass-ware.com/GlassWare_True_Curves.htm
Jan E.
Life is hard - Then you die.
Old 10th July 2008, 09:49 PM   #8
Drat forgot to post the site.
http://digilander.libero.it/paeng/pae.htm/pae.htm
Old 10th July 2008, 10:40 PM   #9
revintage's Avatar
If you want to see how this and other russian tubes work IRL, this is the place to go:
http://klausmobile.narod.ru/testerfiles/6n30p.htm
Brgds
Lars
Old 10th July 2008, 10:50 PM   #10
kevinkr's Avatar
Pretty impressive, I have a few a Russian friend gave me about 8yrs ago, both the 6n30 and 6n6 - I think I ought to figure out what to do with them.. Linearity on the 6n30 even at low Vp is pretty good looking at the curves..
www.kta-hifi.net
using only 1/2 of a dual triode gabriel611 Tubes / Valves 18 2nd July 2010 06:43 AM
Please recommend a 9-pin dual triode = 417A arnoldc Tubes / Valves 2 6th March 2007 10:03 PM
Page generated in 0.09281 seconds (76.19% PHP - 23.81% MySQL) with 11 queries
