diyAudio Sponsor
Old 10th July 2008, 04:47 PM   #1
dsavitsk's Avatar
Default Disassembling output transformer
I have some parafeed transformers that are in channel frames and lacquered up. Is there a recommended way to take them apart? Some way to remove lacquer without actually damaging anything? I have some new lams to use.
http://www.ecpaudio.com
Old 10th July 2008, 05:53 PM   #2
cerrem is offline cerrem  United States
Get out the blow-torch.....
Heat the lams then dissassemble using thick leather gloves....
As you dissassemeble....the lams will cool and varnish will harden..then you may need to re-heat them....
The varnish will start bubbling...where saftey googles, since the varnish may have a air-pocket that tends to pop....
Chris
Old 10th July 2008, 10:28 PM   #3
astouffer's Avatar
I used an old thin steak knife to take apart a tektronix power transformer. Hammer it between the lams to break the lacquer up. The first few are a pain to remove but once you get room to work its much easier.
Old 11th July 2008, 02:14 AM   #4
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
you can try dipping the traffo into a canfull of lacquer thinner and let is stay there for a week....make sure it is covered tight...
this is what i do when i want to preserve the coil....
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Page generated in 0.07120 seconds (70.90% PHP - 29.10% MySQL) with 10 queries
