diyAudio Sponsor
Old 10th July 2008, 06:50 AM   #1
Default Please check my PS pcb board layout for problems????
Hey guys,
I am trying my hand at a scratch built Transcendent Sound GG tube pre-amp. I have built a few kits and I am trying to improve my knowledge of audio schematics, circuits, etc. Can anyone just double check to make sure that my PS pcb board is correct?
Thanks,
Dan
(copyrighted image removed by moderators)
Old 10th July 2008, 12:15 PM   #2
Brett's Avatar
Do it P-P.
Old 10th July 2008, 03:10 PM   #3
Svein_B is offline Svein_B  Norway
Well, I would do p-to-p also.
However if you want to check the PCB, it is a little easier if you print it with the foil pattern together with component lay-out.
SveinB
Old 10th July 2008, 06:28 PM   #4
Thanks Svein! Does everything seem to go together correctly?
Old 10th July 2008, 06:31 PM   #5
Does the program you used have the ability to test the circuit?
Old 10th July 2008, 06:34 PM   #6
SY's Avatar
Dan, I had to remove the schematic since it is the copyrighted property of Transcendent Sound, with a copyright notice right on the schematic. If you want to sketch up your own and post it, that will accomplish what you want while not violating the law.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 10th July 2008, 06:47 PM   #7
Here is the schematic....sorry about posting the copyrighted schematic. The circuit says it works, but I just wanted to make sure that the layout looks okay as well.
Please check my pcb layout! Dominique Solid State 5 15th December 2005 12:31 AM
Layout Check Sherman Tubes / Valves 9 8th December 2004 02:56 PM
PCB Layout check supereri Chip Amps 32 20th October 2003 06:01 PM
A GC Layout check. S.C Chip Amps 120 21st August 2003 04:24 AM
Page generated in 0.09291 seconds (70.51% PHP - 29.49% MySQL) with 11 queries
