diyAudio Sponsor
Old 9th July 2008, 02:16 AM   #1
gary h is offline gary h  United States
Default rectifier tube recommendation please
Hi all,
What rectifier tubes come recommended for a line stage PS given the following:
5V heater supply
300VAC B+
no size or pin count limitations
slow start
long life
less than $20
Thanks,
gary
Old 9th July 2008, 02:57 AM   #2
tubewade's Avatar
Hmmm. Well, right off I think of 5W4GT because it has fairly low heater requirements and is economical. It is directly heated, though, so it won't really be slow to start. You could go with 5V4GA since it is indirectly heated and economical but the heater requirements are a little higher.
Of course, 5AR4/GZ34, but that may be out of the price range.
All of these are overkill as far as current handling ability is concerned.
Wade
Old 9th July 2008, 03:51 AM   #3
Gary,
Jim McShane shows a Russian 5V4, with a $4.50 price tag. That's about as inexpensive as it gets. Jim also carries Chinese 5AR4s, with $9.75 "stickers".
Eli D.
Old 9th July 2008, 03:54 AM   #4
thanks guys
gary
Old 9th July 2008, 04:27 AM   #5
alexg is offline alexg  Philippines
alexg's Avatar
I bought JJ 5ar4 for less than US$20.00 from tubestore.com (US$15.95 excluding shipping).
This 5ar4 works great on my KT88 amp.
Old 9th July 2008, 01:39 PM   #6
Klimon is offline Klimon  Belgium
And these sound really good too......
Simon
Your recommendation on rectifier diodes? riotubes Digital Source 5 28th June 2007 07:50 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Plitron/Vanderveen/KT88 Tube rectifier recommendation for 230mA? Layberinthius Tubes / Valves 13 26th March 2004 05:12 AM
Page generated in 0.07839 seconds (73.33% PHP - 26.67% MySQL) with 10 queries
