| diyAudio Sponsor | ||
Hi all,
I'm trying to figure out values for an LCLC(RC) filter section for my Aikido line stage preamp. I'm having a bit of trouble in PSUD2 due to not really knowing what I'm doing. John Brosky recomends a choke filtered B+. Anyway, having read and searched the forum I'm working with the following assumptions and questions: Inductance of L1 is Vp/Ip. So around 300VDC after tube rectification to 4 6SN7s (10mA each) is 7.5H. Am I on the right track or does the capacitor pairing change this? I have options for choke resistance (300-700 Ohms,) lower is better? How much extra choke current rating is recommended? Having read warnings about dual LC sections ringing, is this easily solved by making the L2 a higher value? If so, 10, 20H? Or just use one LC? (I'm hoping to maximize lower frequency, minimize high frequency noise, but am willing to lose some voltage.) Thanks for the help, I hope to have the PSUD2 model working once I get these values within reason, so far I have been unable to successfully simulate. Also, how can I estimate the line section load for B+ in psud2 without having built it yet? Is it as simple as the speced plate resistence *4 (6,700*4=27kOhms?) To model a full wave tube rectifier in psud2 it shows 2 tubes. I'm planning on using a 12X4. Can I just ignore this symbolic difference? I better stop now before my head explodes. (And yours.) Thanks in advance for the help. gary |
#2 |
Hi Gary,
The choke size is correct. The formula is V/(I*6*PI*f). For the cap, I normally use 1uF per mA. For modeling, you can use LTSpice also called Switchcad from LT. The page is http://www.linear.com/designtools/software/ It is free. For tube models, visit Duncan's page: http://www.duncanamps.com/spice.html I modeled a choke first PSU with the above. I had to add a snubber (47k+100nF) after the rectifier to eliminate HV peaks. I have yet to build it. Maybe next year. Sigh. Have you got a copy of the Radiotron Designer Handbook? I don't remember the latest edition. Third, I think. It has been digitized (.pdf) and can be bought online from tube/audio magazines. I remember it is also posted free on the web somewhere. It has excellent info on the design of PSU. LC, 2 sections LC... Good luck. Serge
'I have no faith in prayer that's not electronically augmented' Philip K. Dick "A Maze Of Death" 'I have no faith in bimbos that are not surgically augmented' Serge66 |
#3 |
#4 |
thanks Serge,
I've seen the small cap before the choke in other schematics, will this help mitigate turn on and turn off noise? I'll check out the link, thanks a lot. gary |
#5 |
diyAudio Moderator Emeritus
A small cap before the choke (0.68uF seems to be a favorite value) can be applied to reduce noise from the choke in a choke-input filter.
A 0.01uF 1,000vAC cap across the power tranny secondary can be used to suppress spikes for the protection of rectifier diodes. |
| Choke rating for choke input duty | cbutterworth | Tubes / Valves | 14 | 9th November 2007 04:43 PM |
| Swinging choke vs std. choke in PS | Curly Woods | Tubes / Valves | 2 | 5th March 2007 08:30 PM |
| Swinging Choke or Smoothing Choke | danFrank | Tubes / Valves | 4 | 11th February 2007 11:05 AM |
| L as a choke. | bogdan_borko | Solid State | 9 | 9th September 2006 09:48 PM |
| SS PSU without choke | Mikael Abdellah | Tubes / Valves | 29 | 15th January 2003 04:34 PM |
| Page generated in 0.09099 seconds (77.11% PHP - 22.89% MySQL) with 10 queries |
