| diyAudio Sponsor | ||
I know the 6SN7 is well thought of.
What about the 6SL7 tube? Unfortunately I need the gain, is this the best high mu tube out there? |
#2 |
I just recently completed a guitar amp using a 6SL7 or 6SN7 as preamp and PI to a 6SJ7 to 2 6V6GT's in pp. for approx 14 watts output. The 6SL7 was easily overdriven, and clipped so badly that output was stunted past 12:00 on the vol.
When I used the 6SN7, the amp worked great, though I suspect the actual output is probably less than the hoped for 14W, being a lower mu tube. I have 2 different used 6SL7's, one a GTb, both behaved in a similar manner. This actually may all have been influenced by use of the 6SJ7. An amp using a 6SL7 to a 6SN7 may be a better combination...... The 6SL7 is often mentioned as equivalent to a 12AX7. It actually may be a little more easily overdriven...... |
#3 | |
6sl7 has a mu of 70 12ax7 has a mu of 100 mmmmmm? Ed |
#4 | |
6SF5s are also pretty good in the gain dept, but that one is a metal, octal singleton, not a dual. "The 6SL7 is often mentioned as equivalent to a 12AX7. It actually may be a little more easily overdriven......" No similarity other than that both types have large r(p) (static and dynamic). Otherwise, the 6SL7 is an octal; the 12AX7 a nine-pin mini type. The 12AX7 has a higher u-factor (100 v. 70) higher r(p), and seems to be somewhat less linear. Plate dissipation is also dofferent: 1000mW (6SL7) v. 1200mW (12AX7). Other than that, dunnow since I haven't used a 12AX7 yet. |
#5 |
diyAudio Moderator Emeritus
I use a 6SL7 LTP splitter, feeding 6SN7 differential amp, driving EL34s in triode mode. I have no complaints and the 6SL7 doesn't overload. It's being driven only by a line-level signal from a volume control, so I wouldn't expect it to. I don't need no steenkin preamp!
| Aikido 6SN7 input 5687 output | eeyore | Tubes / Valves | 2 | 27th March 2009 09:17 PM |
| Tube rectified LC PS for 6SN7 Aikido - choke DCR question | LowRedMoon | Tubes / Valves | 3 | 20th June 2008 05:20 AM |
| 6sn7's | irishguy170 | Swap Meet | 0 | 15th January 2008 07:09 AM |
| tube hum in a 6SN7 Aikido - is this weird? | cbutterworth | Tubes / Valves | 16 | 12th March 2007 04:52 PM |
| aikido 12b4 input 6sn7 output??? | cbutterworth | Tubes / Valves | 1 | 26th October 2006 11:06 PM |
| Page generated in 0.08695 seconds (72.07% PHP - 27.93% MySQL) with 10 queries |
