| diyAudio Sponsor | ||
I have an amp with the ubiquitous PP UL EL34 output with a 4300:4,8,16 OPT.
When you change the output to triode mode, as i understand it, the transformer load is less than ideal. Could you improve the load for triode mode by changing which secondary tap you use? In other words, if you have 8 ohm nominal speakers could you improve the load for the triode strapped EL34 by using the 4 or 16 ohm taps? What about 6 ohm nominal speakers? Thanks, Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?" -Adobe Updater |
#2 |
A loudspeaker can easily vary from 2 to 90 ohms depending what
it is asked to do and wether or not it abuses Zobels to fake a more stable impedance... Use whichever tap sounds best, and stop worryin about it. |
#3 |
Use whichever tap sounds best, and stop worryin about it.>>
Exactly! Could not have put it better. |
#4 |
diyAudio Moderator Emeritus
For EL34, the 'ideal' P-P load normally recommended in tube manufacturers' data sheets (e.g. Mullard) for push-pull operation is 6.6k for UL and 5k for triode.
Neither of these modes is all that critical (unlike pentode mode) and I doubt if it matters at all if you continue to use the same speaker tap when you change from one to the other. You might possibly notice a slight reduction in both maximum output power and distortion. My OPT was designed for EL34 in pentode mode, giving a load of 3.5k P-P but I wanted to use triode mode. By using the 4 ohm tap for my 8 ohm speaker, I got 7k P-P, which was 50% higher than recommended for triode mode, but it sounds fine. |
#5 |
kenpeter & andyjevans,
Me no worry, just curious. Transformers are still kind of a mysterious "black box" to me. ray_moth, Thanks for the details. Looks like the 4.3k ohm OPT will be "close enough" to the spec'd 5k ohm. Guess that's why I've never read about anyone recommending using a different output tap when changing to triode mode. Thanks, Scott
| DIY triode | DSP_Geek | Tubes / Valves | 2 | 10th September 2008 05:03 AM |
| Another 3f4 spice triode model: 5718 submini triode | wa2ise | Tubes / Valves | 0 | 5th September 2008 04:31 AM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 12:36 AM |
| Best Cheap Speaker for Single Ended Triode | Patrick Bateman | Multi-Way | 16 | 22nd December 2006 09:17 PM |
| UL to triode | kathodyne | Tubes / Valves | 55 | 21st August 2005 09:05 PM |
| Page generated in 0.07570 seconds (75.60% PHP - 24.40% MySQL) with 10 queries |
