| diyAudio Sponsor | ||
Just finished rebuilding my diytube st70 circuit. In biasing the tubes I found that one of them would only get up to about 20mv. I inspected the circuit, thought I found a fault, and resoldered it. Put it all back together and was happy I was getting appropriate voltage there until I found the problem just moved to the tube next to it, so I swapped tubes and the problem followed the tube.
Is there anything else I should consider before I convict the tube? The tube is a JJ E34L that I purchased as a matched quartet and has about 5 hours on it. Everything biased good before the rebuild. |
#2 |
If it followed the tube, then I would say the tube is bad. I read in another forum the quality of the JJ tubes especially the EL34's is not good.
Sal Brisindi |
#3 | |
Pretty much what I thought... Did you hear the build qualitly was bad or everything about it. They seem to sound great. |
#4 |
I never tried JJ tubes but from what I read in a few forums, I would not buy them at all. I friend of mine had a bunch of EL34's that like to give a light show (sparks) inside the envelope.
Sal |
#5 |
JJ's are excellent sounding tubes, but their QC isn't what it used to be. I just picked up a set of KT88s, and after about 20 hours, one became a drifter. TubeDepot sent me a replacement within 2 days, now every thing's great.
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz |
| Positive bias for tube CF? | pftrvlr | Tubes / Valves | 5 | 13th May 2007 04:30 PM |
| Please need help! TUBE BIAS PROBE | fiendish | Tubes / Valves | 3 | 11th April 2007 06:44 AM |
| Bias the new power tube | TRAN TUAN KHANH | Tubes / Valves | 2 | 11th April 2005 11:33 AM |
| tube bias pot question | chalieroundeye | Tubes / Valves | 2 | 2nd June 2004 08:27 AM |
| Tube Bias question | Rino odorico | Tubes / Valves | 13 | 17th September 2002 09:48 PM |
| Page generated in 0.07768 seconds (72.94% PHP - 27.06% MySQL) with 10 queries |
