| diyAudio Sponsor | ||
Hi all,
I'm looking at Thorstens table of values for 24 position stepped attenuator. On the input to wiper side the first 11values are a fixed 100K. My question is - can I simply link all these switch positions together and use a single 100K resistor for all 11 positions?? Shoog |
#2 |
which version?
link
regards Andrew T. |
#3 |
The "Eurdice" preamp with a Ladder attenuator.
Shoog |
#4 |
eurdice does not show up in a Forum search.
regards Andrew T. |
#5 |
As I'm sure Shoog has realised, logic says that one 100k should be identical. I guess build it and see.......
#6 | |
Here's the link; http://www.fortunecity.com/rivendell...eBuilders.html Shoog |
| diy stepped attenuator under 10$ | kaushik | Parts | 23 | 12th January 2012 10:37 AM |
| Stepped attenuator | sonokeling | Parts | 0 | 11th July 2006 09:05 AM |
| Stepped attenuator | Bas Horneman | Tubes / Valves | 24 | 16th June 2004 07:18 AM |
| Stepped Attenuator | officeboy | Parts | 3 | 6th May 2004 03:32 PM |
| Page generated in 0.07638 seconds (78.51% PHP - 21.49% MySQL) with 10 queries |
