| diyAudio Sponsor | ||
diyAudio Chief Moderator
Hello, does anybody know the settings for testing KT88 on a TV-7/DU tester? P.S. If you have a TV-7/DU settings list for most popular tubes used in HI-FI, it will be nice to post here. |
#2 |
I think I will experiment with 6.3v, Selectors: HS-5348-1 bias 40- Shunt 40 & conduct. button. I see nobody seems to use TV-7s here. If I will get good results I will let you know the final settings just in case someone will need them in the future.
#3 |
file:///Tubes/TV-7_newtubes.htm
| question about amp settings | pat99 | Car Audio | 2 | 18th December 2005 06:33 PM |
| eq boost/cut settings | ocool_15 | Car Audio | 0 | 10th April 2005 12:00 AM |
| Settings | the_wonderchild | Multi-Way | 2 | 7th August 2004 02:06 PM |
| Page generated in 0.05988 seconds (72.16% PHP - 27.84% MySQL) with 10 queries |
