diyAudio Sponsor
Old 5th July 2008, 01:55 PM   #1
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Default Hybrid Amp, Tube+MOS FET SE
I have completed to make a Hybrid Amp using tube for
voltage amplifier and MOS FET SE (source follower) for
output. The measured results are shown in the attached
file.
The sonic is clear and wide ferq range.
Old 5th July 2008, 02:03 PM   #2
bigwill is offline bigwill  United Kingdom
Looks like a good circuit, I bet it sounds great! I like tubes but don't have a problem with Class-A MOSFET output stages
Old 5th July 2008, 02:12 PM   #3
Yes, I encounterd a big problem at MOSFET. It was cooling
problem. Finally, I used a forced air heatsink with heat pipe
scheme for Core Two Duo CPU. Before this heatsink, 6 MOSFET's
were destroyed.
Tube Hybrid Amp. neg2led Tubes / Valves 11 3rd September 2006 12:38 PM
Hybrid amp -> tube for VAS stage rtarbell Tubes / Valves 3 26th November 2005 09:13 PM
tube/SS hybrid (low power)- need tube help trespasser_guy Tubes / Valves 26 6th July 2003 07:15 PM
tube/ss hybrid mic preamp help! mwmitchell Solid State 0 4th August 2002 01:11 PM
Page generated in 0.07615 seconds (72.70% PHP - 27.30% MySQL) with 11 queries
