diyAudio Sponsor
Old 3rd July 2008, 11:54 PM   #1
Default question about Bruce's GGP preamp
Hi Guys,
Someone read to me the chapter out of Bruce's book, Audio Reality, the chapter on the Grounded Grid Preamp. My question is he mentioned in passing about using a FET for a CCS, but decides to have the B Minus supply anyway. I am just curious if anyone has tried the CCS anyhow. He also mentions the second tube is being used as a CCS on the plate side. Just curious if anyone has used a Solid State device for the CCS instead of a tube? Just curious. It would seem that there would be a lesser parts count if he at least did the first CCS. He would not need the B Minus supply at all.
Thanks.
Ray Bronk
Old 4th July 2008, 06:52 AM   #2
Why don't you ask these questions on Rozenblit's own website - that's what it's there for.
Old 4th July 2008, 01:03 PM   #3
It's real simple. I still do not know what I did, but I have been banished from his board. So I can not ask that question there.
Besides this forum is a whole lot bigger than his little message board.
Ray Bronk
Old 4th July 2008, 01:24 PM   #4
SY's Avatar
I haven't built his particular circuit (nor seen it, except second hand), but as someone who has traveled the CCS route several ways, I wouldn't hesitate to use a solid state current source- IF it's designed correctly, it will run rings around a tube version in terms of source impedance and bandwidth. And unlike a pentode, SS can be used as a source (e.g., a plate load) as well as a sink.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 4th July 2008, 02:08 PM   #5
Hi Sy,
If you look at this circuit, he uses a tube for one of the CCS at the plate. This way, he doesn't have to use resistors, and it sounds better. The other one I think, if memory serves me correctly, is at the Cathode, where he just mentions the use of a FET. He even says that this would then eleaveate the need for the B mimus supply. I would think that something like an LM317 and whatever value resistors would be a lot cheaper than an isolation transformer, and its associated parts. I am more interested in the Cathode version of the CCS versus replacing the second tube.
So being a novice at this, would I have to use three different CCS circuits on each of the three tubes?
Ray Bronk
Old 4th July 2008, 06:20 PM   #6
Gordy is offline Gordy  United Kingdom
The company Analog Metric make a kit that they call Grounded Grid. I do not know if it is a rip-off of the Transcendent design or something completely different.
The circuit was here at this link: http://www.analogmetric.com/store/ga...?id=90&img=366
I'm no vacuum tube expert, however it looks like the output stage is a SRPP configuration, and that the lower triode also forms a Long Tail Pair with the input triode. They use a resistor (and not a CCS) as a tail for the Long Tail Pair.
If I was to build it I would be inclined to do it exactly as designed, and then change it one part at a time later on. In that way it is likely to work from the off, and then you can learn how the modifications influence the design as modifications progress.
Old 4th July 2008, 06:46 PM   #7
SY's Avatar
Looking at the circuit Gordy linked to (you'll have to tell me if it's the same as the GG), it's a cathode-coupled SRPP. R13 and R14 could and should be replaced by a decent quality CCS. If it were me, I'd bite the bullet, put in a -10-15V supply, and use a bipolar cascode CCS in that spot. Very cheap, easy, compact, and high performance. If you have a large negative rail and either a spare separate heater supply or choose tubes with the appropriate max heater-to-cathode voltage rating, that current sink can also be a pentode, which will work nearly as well.
New designs for Curvy Bruce atilsley Full Range 27 12th March 2009 10:18 AM
Bruce + subwoofer broughd Full Range 45 19th December 2007 02:09 AM
will Bruce work with my Pana 8 TS? freddi Full Range 0 26th July 2007 10:02 PM
BIB or Bruce 1.1 for AN8 hwong Full Range 42 17th January 2007 09:49 PM
Page generated in 0.09939 seconds (81.92% PHP - 18.08% MySQL) with 10 queries
