diyAudio Sponsor
Old 3rd July 2008, 02:19 PM   #1
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Default ORIENTED or Not ORIENTED cores for OPT
Does someone explain the difference of sonics between
ORIENTED core and Not-ORIENTED core of Output
Transformers with E-I shape core.
Old 3rd July 2008, 03:41 PM   #2
Hello ja2dhc
More Henry at same size.
Kind regards,
Darius
Old 3rd July 2008, 03:48 PM   #3
Doug Kim's Avatar
Sonics still same?
Doug
Old 3rd July 2008, 05:22 PM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
A grain oriented core (such as a C-core or a toroid) will saturate more sharply than a non-oriented core (such as an EI core).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 4th July 2008, 09:57 AM   #5
Tweeker is offline Tweeker  United States
Cores (for audio and power transformer applications) mostly use Grain Oriented Silicon Steel. C-core and toroids have all of the flux parallel to the grain, whereas the is not the case in some regions of the EI.
Non oriented steels have lower saturation density, although this is improving. These steels are often used in motors.
Be sure your foil hat has a good low impedance ground.
Old 4th July 2008, 10:04 AM   #6
Thanks Tweeker. That point is my concern. What is the
impact to sonic caused by this irregular flux path ?
Old 4th July 2008, 10:42 AM   #7
Geek's Avatar
I have taken a professionally wound bobbin and filled it with M4, M6 and some garbage from a cheapo-of-el-cheapo power tansformer.
Above 100Hz, I couldn't hear much difference and above 1KHz, none.
Below 100Hz, BIG difference. M4 was clean and full, M6 tight, but not as deep and the garbage was... well... garbage.
I have no idea if this helps, just the results of an impromptu bench test
Cheers!
Old 4th July 2008, 07:48 PM   #8
richwalters's Avatar
Commercial good quality stuff M6, the BH curve hasn't really improved for decades.
Quote:- Below 100Hz, BIG difference. M4 was clean and full, M6 tight, but not as deep and the garbage was... well... garbage.
No not really, when iron gets close to saturating on the BH curve the 2nd harmonic becomes dominant and the MI industry knows that lower fundamental lower f1 notes can't be reproduced on smaller bookshelf systems. So 2nd harmonic sounds with fuller bass on small box LS systems. Result, big bass extension systems can often sound too heavy reproducing both harmonics. One have it both ways but one needs to back off on the bass control.
E&I cores saturate smoothly as permeability is higher due to inherent airgaps within stacking laminations. An advantage with p-p tube o/p trannies as out of balance currents can be tolerated without performance problems.
Not all CD's and sound source studio techniques are uniform. The music market assumes most listeners have smaller bookshelf systems.
true/false ?
Question:-
How may audioforum users have bass speaker systems i.e 5Cuft (140Lit) or larger that can get down to 25Hz ?
richj
Old 4th July 2008, 08:01 PM   #9
kevinkr's Avatar
Pair of 11 cu ft bass modules.. Usable output down to about 35Hz.. (Jensen Ultraflex/Onken) Dropping rapidly below 30Hz...
www.kta-hifi.net
Old 4th July 2008, 09:19 PM   #10
EC8010's Avatar
My last loudspeakers were transmission lines that had a bit of a bump at 20Hz. The new loudspeakers will be open baffles and will fall away at 18dB/oct from 40Hz; I'm hoping the lower Q resonance will be better.
How hot do E-cores get? Dr.EM Parts 5 26th January 2009 10:13 PM
Desing oriented speaker with Manger hahfran Multi-Way 7 22nd July 2008 05:51 PM
Grain oriented silicon steel core data needed eppidei Tubes / Valves 0 14th September 2007 02:08 AM
First time build help needed budget oriented sbrunkow Multi-Way 1 24th October 2006 05:23 PM
Starter set - PC speakers and amp Music oriented PatR Multi-Way 4 27th December 2003 05:31 PM
Page generated in 0.10128 seconds (80.91% PHP - 19.09% MySQL) with 10 queries
