| diyAudio Sponsor | ||
Hi, I own an Audio Reseach SP-3-A-1 that was modified when I purchased it. The changes would appear to be the CAE (Cureio Audio Engineering) modification instructions for changes available over the web. The connections are (I assume) correct because it does play. The work is extremely slopply and I want to reverse engineer the thing and restore the bass, treble, and contour controls. Two tubes (V7 and V8) for the tone control circuit are pulled. Now, I'm wondering if that if I just plug 12AX7's back in if I'll have tone controls, or were all the preceeding changes in steps 1-10 also affect the tone controls. If so, which changes do I keep and which changes do I put back? Basically I want to end up with the changes to the RIAA, Regulator Circuit, and "Beefed-up" bass response ONLY. I for one think that the tone controls SHOULD be there to use. This is the link to the CAE instruction: http://www.curcioaudio.com/SP-3%20Mo...umentation.pdf
Ray Corte (San Jose, CA)
| Audio Research D-90 | rudy129 | Tubes / Valves | 4 | 11th June 2010 01:19 PM |
| Carver mk II modified audio amplifier | RichP714 | Swap Meet | 41 | 11th February 2009 03:52 AM |
| Audio Research SP6 E | PIERRICK | Tubes / Valves | 1 | 26th November 2006 10:03 AM |
| Modified Audio Note M7 Tube Pre Amplifier PCB | rick57 | Tubes / Valves | 9 | 20th May 2006 08:21 AM |
| Audio Research V70 | aeon845 | Tubes / Valves | 0 | 8th March 2004 01:04 PM |
| Page generated in 0.06676 seconds (69.06% PHP - 30.94% MySQL) with 10 queries |
