diyAudio Sponsor
Old 3rd July 2008, 02:10 AM   #1
nigelwright7557's Avatar
Default Tube heaters in series.
I have built a pre amp using an ECC83 and wired the heaters in series.
I have noticed on power up from cold one heater glows considerably brighter than the other for about a second and then things settle down.
Will this damage the valve or could it cause unreliability ?
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd July 2008, 07:41 AM   #2
Geek's Avatar
Heater "flash" is common in the 12A_7 valves (especially nasty in many 12AT7's).
You do need a controlled heater warmup for series stringing though - denoted by an "A" suffix in the US numbering system. Don't know what it is for european types.
Cheers!
Old 3rd July 2008, 01:52 PM   #3
This problem is typical of series AC or DC heaters operated without a constant current source. The one and only way I know to eliminate this problem is to feed the heater series string with a DC constant current source set for the specific current of the heaters.
I have this set up in my current amplifier project and it works great. My implementation was with an LM317 wired as a constant current source and it is feeding just the front end voltage amp stage and the differential LTP phase inverter tubes.
MickeyStan
Old 3rd July 2008, 01:55 PM   #4
Many thanks for your help.
Nigel
Old 3rd July 2008, 03:40 PM   #5
MickeyStan
Not that there is anything wrong with using a CCS or a current regulator of some sort, but the fact is certain tubes "flash" whether they are in a series-string or not. It's part and parcel of the heater wire material used by some makers.
BTW, a slow start voltage regulator will work well too - the circuit in the great 1982 National Semiconductor Voltage Regulator Handbook works quite well. IIRC that book has been reprinted, I think the Audio Express/Old Colony people did it but I'm not sure. They do show up on eBay from time to time.
Old 4th July 2008, 09:11 PM   #6
Due to some hum problems I changed from AC heater supply to a DC supply. Its didnt make very much difference to the hum but the flashing has now stopped ! All I use is a half wave rectifier into a 100uF cap to feed the heaters. Its possible the heater voltage is slightly lower and that has stopped the flashing.
Thanks for the advice.
Nigel
PL519 Heaters in series blow fuse wiysel Tubes / Valves 5 6th November 2008 11:18 AM
Tube heaters AC or DC? soundbadger Tubes / Valves 105 1st March 2008 10:04 AM
Tube current regulation for series heaters' supply. engels Tubes / Valves 4 5th August 2007 10:49 PM
Series heaters = small problem? Klimon Tubes / Valves 5 13th May 2007 11:12 AM
Series wiring for heaters XZur Tubes / Valves 5 19th December 2005 02:43 AM
Page generated in 0.09456 seconds (74.33% PHP - 25.67% MySQL) with 10 queries
