Time to mourn the death of Broskie's Tube CAD blog? - Page 9 - diyAudio
Old 17th October 2008, 04:46 PM   #81
kevinkr's Avatar
I know what rdf means by direct browse, it is the non search based feature found on the mirror sites where you click through various links until you get to the part of the particular archive where the file you are looking for is located. (A manual search sort of)
I clicked on any number of links to tube data sheet pdfs in the page returned by the search and got the 404/403 "forbidden" errors mentioned by others.
I have already emailed Frank as of yesterday and am waiting to hear back. (You may have gotten a more current email address so you should too in any event.) I also started a thread specific to this issue yesterday.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th October 2008, 05:37 PM   #82
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
If this is the site I have no problem to read datasheets...it seems to work like usually
"Search" tool works perfectly too
http://frank.pocnet.net/sheetsE.html
sometimes we know very little, and sometimes we know too much
Old 17th October 2008, 06:27 PM   #83
kevinkr's Avatar
Read my previous posts then click "Search" in the upper right hand corner of this page, type in any valid part number, click on any one of the resulting links and you will understand what the issue is.
Old 17th October 2008, 06:47 PM   #84
Default Mirror is working
OK, I see: a mirror at pocnet.net is working, if you search on the mirror, you are redirected to the original hosting at www.mif.pg.gda.pl that has problem with the access.
Old 17th October 2008, 06:54 PM   #85
rdf is offline rdf  Canada
rdf's Avatar
I haven't had a single direct datasheet retrieval fail yet. Global routing issues?
Ears aren't microphones.
Old 17th October 2008, 07:23 PM   #86
The datasheets CAN be retrieved at the mirror in the browsing mode, only search redirects to "unretrievable" files at the main hosting.
Old 17th October 2008, 09:21 PM   #87
kevinkr's Avatar
I just heard from Frank, he is aware of the problem. He recommends just using the local mirrors to get any files you need, using browse as opposed to the search. He did not give any specific time frame for when the search function will be fixed.
First time DIY tube squiggy Tubes / Valves 2 14th January 2007 11:52 PM
First Time tube amp - need help soundNERD Tubes / Valves 12 25th October 2003 08:22 AM
First Time Tube Amp cummic Tubes / Valves 7 9th July 2003 11:34 AM
First time building a tube amp: Help please JAZZ2250 Tubes / Valves 36 28th June 2003 09:37 PM
First time Tube Amp Milzie Tubes / Valves 13 5th December 2002 06:28 PM
Copyright 1999-2017 diyAudio
