| diyAudio Sponsor | ||
Which would you choose? I lean towards A, as it minimizes loop area, though it does have a closer proximity to both triodes, not just one.
#2 |
I always use A. But didnt have problems with B either.
#3 |
I like to use B, since I lay down the heater wiring first close to the chassis, and keep the area between pins open for p-p components added later.
Svein. |
#4 |
Definitely B for the reasons above.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#5 |
Well I tend to use DC... JK When heating with AC I may use A or B depending on circumstances - have also twisted tightly together as far as possible and looped up and then straight down the middle.
These days I mostly use types with adjacent filament pins and therefore do not have to deal with the issue specific to 12XX7 series stuff. Minimizing loop area seems to be the key in most cases. Floating the filaments and biasing them up to some dc level above ground often makes more difference than anything else.
www.kta-hifi.net |
#6 | |
#7 |
This brings up a point that I have not seen addressed. Routing of heater wires is easy for a guitar amplifier since all line level signals enter and exit the amp on the front and the controls are also on the front. Thus the heater wires can be routed along the back and they are kept far apart for the most part.
The hifi amp is a little bit different as the controls are on the front but the line level signals come in and out of the back of the amp. So it becomes more difficult to keep the signal wires away from the heater wires. I see several options and would like your input as to the best approach. You could keep all of the signal inputs at one end of the chassis and route them around an into the tube sockets from the front while keeping the tubes as far to the other end of the chassis as practical. The down side is that the chassis must be larger and will be visually unbalanced. Another option is to put the heater wires against the back as in the guitar amp and just run the shielded signal wires over the heater wires exactly perpendicular to each other. Thus you would be depending on the shielding, twisting and orthogonality of the wires to keep the hum out of the signal wires. This has some amount of convenience to it but I wonder about the effectiveness of this approach. The other idea is to run the heater wires down the center and loop the signal wires around one end of the chassis. The concern here is that the heater wires are only up against one chassis side instead of two and though the wires are far apart they are parallel for a lot of the wire's length. Your thoughts?
mike - www.keepingsundayspecial.org |
#8 |
I just keep the IEC socket on the rear of the chassis on the left hand side as viewed from above. Run the 240v live down the left hand side to the front power switch. All heater wiring down left side, then along front of chassis, tucked in to corners, tightly twisted.
On right hand side at rear RCA inputs. Input shielded signal wire down right hand side to input circuitry of first valve stage, keeping away from mains and heater wiring. B+ down centre of chassis. Zero volt bus parallel to front of chassis behind valves. Followed this basic pattern for the last couple of amps and have had no hum or buzz problems. This is my latest, finished yesterday. Heater wiring is tucked in to corner, so not visible, but it is the blue and yellow twisted pair. Power supply is on the right, signal circuitry on the left. Did not take too much trouble to keep wiring neat, but there is zero noise. ![]() This one is a little more complex, constant current for input and driver. Main power supply upper left. -15V supply for CCS lower left (as viewed). Heater wires run on the top and down right edge as viewed, then directly from corner to valve socket. Sockets are orientated so that pins 4 & 5 are towards the front of the chassis to allow heater wiring to remain clear of signal wiring. ![]() I think this is pretty much as recommended by Morgan Jones in his books. Chris. |
#9 |
Great input. What do you do about controls (vol and selector etc) on integrated amp or preamp?
#10 |
I avoid that tricky problem Mike by only building power amps
Seriously, the only amp I built with a volume control followed the same pattern above, but with the shielded inputs running down right hand side to the volume pot on the front of the amp on the right side, then from there to the input valves. My main system has a Rotel surround sound pre amp, and the other amps for office use have been hooked to computer or iPod, so just using the volume control on the source devices. Cheers, Chris |
| AC or DC for 300b Heaters | sgerus | Tubes / Valves | 73 | 22nd May 2007 12:48 PM |
| PSU for 12V DC heaters | cbutterworth | Tubes / Valves | 15 | 9th March 2007 06:25 AM |
| Series wiring for heaters | XZur | Tubes / Valves | 5 | 19th December 2005 02:43 AM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| Help with hum in AC heaters | HeadSh0T | Tubes / Valves | 21 | 27th September 2003 12:40 AM |
| Page generated in 0.10979 seconds (79.87% PHP - 20.13% MySQL) with 11 queries |
