| diyAudio Sponsor | ||
#21 | |
#22 |
Oh, you liked that one did you?
Now contemplate this if you dare... We have: 4th Circuit - Differential Fetrons, Two Common Noises ref'd to B+ "Brute Force" DC current balance. DVC Sub abused as a self-OPT H-Bridged Full Ranger. ------------------------------------------- Fetrons differ from triodes mostly in having a low impedance at the gate. Having "external-insic" NFB to defeat intrisic "screeni-ness". One has to be careful to drive from a well controlled impedance, as the ouput of the driver becomes part of the input mixer/divider to the Fetron. Same could be said for OHSchade's 1938 triode emulation, abusing beam power tubes with screens tied high. The same OTL circuit with slightly different bias could be done with a gang of regulator triodes. The 4th circuit "Long Neck(s) Pair" is the same either way. -------------------------------------------- Gratuitously threw a beam tube in place of original depletion FET at the input, to keep it plausibly relevant. No rule against replacing FETs with real tubes! The high plate impedance lets the load resistor alone set the stable predictable driving impedance the Fetron will want/need to see. -------------------------------------------- No component values specified, just the way we like em! I'd prob suggest networking a low Mu for the Fetrons, to keep the swing of the Drains/Plates from wasting too much of B+. Never suggested this circuit was efficient, nor practical. Only another half baked excercise in circuit abuse. Blindness Warning! |
#23 |
Ken,
You must be smoking some pretty strong weeds over there. I take it that "long necked pair" refers to a "plate" connected pair. Now what is DVC and FR? This is looking more like, can I say "normal" without breaking some conventions, P-P now, rather than a Circlotron. But Fetron tube emulations in both forward and reverse directions, definitely breaking all the usual rules. My guess is that the reverse Fetron is not getting equal gate drive though, unless the resistors are tuned differently. Shouldn't the input tube have some plate feedback too? What you need is a tube with interleved spiral grids at the same distance from the cathode. Then use one for input, and the other for output. There are some dual control tubes that have two grids and two plates, but are on opposite sides of the cathode. Not sure how well they would share the cathode current. The 7360 beam deflector is probably as close as one can get to this geometry. Don
Ohms Law V = I R |
#24 |
Normal? No never... Refer to Technical Forum Rules
DVC=Dual Voice Coil, make all that excess overhung bifilar inductance actually do something (useful?). FR=Full Range, or whatever passes for full range... Wasn't going for Circlowhatsitnot or Loftin this time. Not that I wouldn't go there. Difficult to smoke every variety of electric mushroom at once and still able to post. Don't have to explain that to you, now do I? I chose a high impedance pentode plate for the input, so not to mess with the voltage divider of the Fetron. Actually the driver to a Fetron can be any impedance, so long as it isn't significantly dynamic or reactive... And the combined bias and local NFB network must be tweaked to accommodate those changes. A low impedance follower with a series resistor out is another stable way to drive a Fetron, but that would be too normal. I wouldn't get to float on B+ ripple... Where is the challenge then? I would bypass the other side's "drive" to ground instead of B+, boring! Any emulator that won't work in 4th circuit topology doesn't emulate a Triode in my book. Too many sand state circuits that claim to act like tubes simply do not pass any test of realism under dynamic variance of plate load... The Long Neck Pair works fine with a single high value Resistor, CCS, Choke, or Gyrator... I happen to choose a CCS split in twain, then bridged with a capacitance. MJK dubbed one my previous split source "Brute Force". Of course, that was for a much higher value cap to bridge a Cathode to an AntiTriode's Source. On the difficult low impedance "Tail" end of an earlier Triode / Anti-Triode differential pair. There is no Anti-Triode in this schematic, so stop looking. There is also no "Tail" except the actual load itself. Look to the phase dot(s) of the DVC windings. Its wired only to behave as a common mode short, and a differential mode load and self-choke.... I think the 4th circuit's "Neck" has high enough impedance to allow a much more reasonable capacitance in the split current source bridge. If a forced perfect "brute force" DC balance is actually needed, and in many cases it is not. The cap on the FR must bridge the low impedance end of the pair, but not the lowest notes as handled by the DVC. Even this cap therefore might be of a reasonable value... |
#25 | |
Hello Don,
And this isn't for the first time here. Thus his schematics can be interpreted in different ways, of course. This makes it possible for him to say "you are wrong" etc. But I didn't say anything in post 21 "Blindness" comes from his mind. Ken is very annoyed. I don't like to feed him any more. Kind regards, Darius |
#26 |
Topology brainstorming sessions don't always need specific values.
A lot of these wacky ideas will never go any further. I do attempt to fit values to an idea when I think there is a need to further test if it can be biased properly. And have done so even in this thread. Annoying is when a guy offers to help explain a difficult topology, and then withdraws that help because you can't teach a mosfet from Texas to sing a CHB, or whatever sigline was at that time... If I have to figure it all out for myself, you shouldn't be offended when I occasionally draw the wrong conclusions, or more often take your good traditional ideas down an unexpected tangent... I don't like when your posts are missing the |
| Concertina sanity check | PeteN | Tubes / Valves | 12 | 27th June 2007 03:54 PM |
| to parafeed or not to parafeed that is the question | nhuwar | Tubes / Valves | 63 | 28th February 2007 12:29 PM |
| Help Please Guitar Project Mess | Trout | Tubes / Valves | 7 | 15th September 2005 03:45 AM |
| Classification Mess Up | freedom | Solid State | 2 | 15th November 2004 04:32 PM |
| Page generated in 0.09732 seconds (83.59% PHP - 16.41% MySQL) with 11 queries |
