| diyAudio Sponsor | ||
Hi all.
I just got my version of Richard Murdey's 6DJ8 phonostage up and running, and it sounds just fine. http://www.geocities.com/rjm003.geo/.../diy_pho3.html I don't hear any real difference beetween it and my Hafler DH110 which by what I have read has an excellent phono section. My turntable is nothing very special however. Here are some pics. |
#2 |
Or here they are
#3 |
That's inside the psu. I haven't drilled vent holes in the lid yet.
this is the phonostge itself. |
#4 |
Also, thank's to Tubewade and Hotbottle for their input when
I was planning this project. |
#5 |
Looks great.
I need to do a phonostage soon (am using a crappy SS phonostage) and I was looking at the hagtech's cornet octal (6sl7 and 6sn7) and this phonostage (6dj8) but since I have tons of 6n1p, I might do a 6n1p phonostage with slight modification of the circuit. Great job on your 6dj8 phonostage. |
#6 |
BTW, how is the gain of the RJM phonostage?
I read in another thread that the estimated gain of this phonostage is around 35db. My preamp does not have too much gain so I am a bit worried about the low gain of the phonostage. Thanks. |
#7 |
Hi.
Richard Murdy's page on this amp says 38db. Should be about 90x. 30x per stage with a 10 (20db) loss in the passive filter. I am using a Hafler 110 preamp. the volume settings are about the same as when using the built in phono section. The sound is just as good too. The Hafler phono has a very good reputation. So I didn't really need the tube phono but it was a fun project. Watch out for hum. I just left the heaters floating and got alot of hum. I have grounded one side of the heaters at the outboard psu and the hum has dropped alot. I am going to ground them in the amp instead and see how that works. I don't really want to reference heater supply to a positive voltage because the rectifier diode heater uses the same supply. Since taking theese pictures I have fiished the lid for the psu. Now I need to finish the case for the phonostage. Rolf. |
#8 |
Are you using an IDH rectifier? If so then, I think, referencing the heater at a higher voltage (within reason) should not be a problem and I would think that it would make a world of difference. Tightly twisted heater wires is of course recommended as well. I did this on a high gain guitar amp and there was absolutely no audible hum.
just a newbie's opinion.
mike - www.keepingsundayspecial.org |
#9 |
I gather that your heater supply does not have a center tap for ground. I don't think you need to reference the heater to a positive supply, the cathode voltage is very, very low.
If you don't have a center tap heater supply, try connecting each leg of the heater supply to ground with 100 ohm resistor. This seems to work for me. I started drilling my chassis for this preamp, but I will be using 6n1p because I have tons of them. Thanks. |
#10 |
Hi Mike.
Yes it is an indirectly heated diode a 6x4. I would't think it would be possible to share heater supply with the amp triodes otherwise. Thank's for sending those plugs. I did go with a different connector however. alexg, I think I will try you idea. good luck with your build! ps. I did twist the heater wires. |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| phono stage | sakis | Tubes / Valves | 20 | 24th March 2008 08:22 AM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Page generated in 0.10774 seconds (79.56% PHP - 20.44% MySQL) with 11 queries |
