diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   EL84 driven 2a3 (http://www.diyaudio.com/forums/tubes-valves/125605-el84-driven-2a3.html)
alexg 29th June 2008 02:59 PM
EL84 driven 2a3
Inspired by the circuit described here, EL84 DC coupled to 2a3 , I am planning to build a similar circuit.
But instead of DC coupled EL84 into the 2a3, I am planning of using a Lundahl 1660S interstage (2:4.5) configured as SE-SE interstage.
I just built an EL84 driven EL84 and I was impressed with the results. I have a pair of 2a3 and an idle OPT (though with primary Z of 5K, but it should work), and I like to experiment with the circuit.
Any thoughts?
andyjevans 29th June 2008 09:48 PM
But instead of DC coupled EL84 into the 2a3, I am planning of using a Lundahl 1660S interstage (2:4.5) configured as SE-SE interstage.>>
I thought the 1660S was created as a phase splitter. Wouldn't it be better to use a LL1660 in 1:1?
miklos 29th June 2008 09:58 PM
Looks good and probably souds equally good.
I don't like the color, but I guess if you're Irish it's ok.:)
alexg 30th June 2008 12:27 AM
As far as I know, the 1660s is same as 1660 with a faraday shield.
I am thinking of using 1660s because I have them. :)
The 1660 and 1660S on Alt-T configuration for SE-SE is 2:4.5 only, I don't think that it can be configured for 1:1, but I will check on this. Thanks.
Copyright 1999-2017 diyAudio
