diyAudio Sponsor
Old 28th June 2008, 06:39 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Common Audio Tubes in standard use
I am building an excel spreadsheet of just commonly used audio tubes so i can print my own booklet of settings for my Hickok tube tester so i don't need to sort through pages and pages of tubes for TV, and ham radios and the like. I know many high end amplifiers used uncommon tubes. I am just looking for tube numbers commonly used. the normal 6L6 run of the mill stuff. here is my list so far. what am i missing??? these are not in any sort of order.
5AR4
5U4
5Y3
5881
6AS7
6AU7
6BQ5
6CG7
6DJ8
6L6
6SN7
6V6
6550
6922
12AT7
12AU7
12AX7
EL34
EL84
EZ81
KT66
KT88
Others less common but might be included
2A3
6C33
Old 29th June 2008, 12:35 AM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
6SL7
807
26
45
12BH7
12BZ7
Arne K
Ars longa, vita brevis
Old 29th June 2008, 02:31 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
300B
6AU6
6D22S
E88CC
EF80
Old 29th June 2008, 02:32 AM   #4
Audio Junkie
Zero Cool's Avatar
Thank you, Keep them coming!
Old 29th June 2008, 03:44 AM   #5
Tweeker is offline Tweeker  United States
10Y
5687
5751
6080
6SJ7
Be sure your foil hat has a good low impedance ground.
Old 29th June 2008, 03:54 AM   #6
miklos is offline miklos  Canada
EF86
EF804
E80CC
miklos
Old 29th June 2008, 11:45 AM   #7
5Y3
5U4
5V4
300B
845
45
10
6H1П, 6H23П (6DJ8,6922)
6H2П (12AX7)
6H3П (2C51, 5670)
6H6П, 6H30П (Much hotter filaments than 6DJ8, ECC99?)
6H8C (6SN7)
6H9C (6SL7)
6H13C (6AS7G)
6П3С, 6Л6 (6L6)
6П6С (6V6)
6П1П (6AQ5)
6П14П (6BQ5)
6П18П (6DY5/EL82)
6C4C (6B4G)
6C4П
6C19П
6C45П (WE-437A)
П=P, C=S, H=N, Л=L
Old 29th June 2008, 11:56 AM   #8
jane is offline jane  Norway
jane's Avatar
6BX7
6BL7
ECL86
ECC99
6FQ7/6CG7
12B4
6EM7/6EA7
6J5
(6R7, 6SR7, 6Q7, 6SQ7)
JanE
Life is hard - Then you die.
Old 29th June 2008, 08:50 PM   #9
kevinkr's Avatar
5842/417A
D3A
GZ32
5R4
01
12A/112
211
12BY7
www.kta-hifi.net
Old 30th June 2008, 12:01 PM   #10
kstagger's Avatar
C3m
C3o
C3g
EF40
ECC40
EL38/6CN6
6C6
310A
6AR6 / 6384
TT21
TT22
7044
7119
6900
E182CC
7199
6GH8A
ok - some aren't that commonly used in commercial designs but still are worthwhile candidates
Krell Audio Standard Sithlord2007 Solid State 0 13th February 2008 01:16 AM
Art Audio Kit on Common Ground Magazine sonata149 Tubes / Valves 2 29th May 2007 10:53 AM
standard cable colours in audio? Dominique Parts 15 27th February 2005 09:19 PM
so i get common tubes free... now i just need a project VictorG Tubes / Valves 36 2nd February 2004 07:06 AM
Page generated in 0.10167 seconds (79.36% PHP - 20.64% MySQL) with 10 queries
