diyAudio Sponsor
Old 28th June 2008, 01:25 PM   #1
Default how easy to make tube amp?
hi,
he.....he....i am a nut about amp ha.. thinking too many things .
i just want to know. how easy to make tube amp? how about the power supply transformer. is there any easy way to make tube amp?
thanks for advice.
Old 28th June 2008, 05:59 PM   #2
oshifis is offline oshifis  Hungary
Very easy or very difficult, depending on your experience and choice of project. I'd start with a kit in your place. Keep in mind that building a tube amp is very dangerous! You need to think twice what you do.
Old 28th June 2008, 07:28 PM   #3
which kit is easy to build. does 100w is easy to build?
Old 28th June 2008, 07:41 PM   #4
leadbelly's Avatar
No.
Please search. This topic is discussed very frequently, and by simply reasking it again, you are likely to get incomplete responses.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 28th June 2008, 11:24 PM   #5
First I doubt you need 100W. Few people need more than 20W. I use 3-5W amps now adays. What the specs of the speakers you plan on using?
I've never dealt with kits before but I would highly suggest the El Cheapo schematic (its on the web somewhere). Before you start tube amps though learn about how speakers work and invest in a decent pair of efficient speakers.
Also don't build amps like me:
Throw something together that looks like it might work and then pray it doesn't kill you when you throw the on switch.
cheap and easy tube preamp juuzo` Tubes / Valves 1 18th May 2009 05:21 AM
Easy PSU question - help me make this 12v DC power supply better. owdi Power Supplies 8 2nd May 2007 04:42 PM
DIY Turntable Concept (Easy-to-make) comabereni Analogue Source 10 10th November 2004 10:30 PM
Page generated in 0.07610 seconds (72.66% PHP - 27.34% MySQL) with 10 queries
