| diyAudio Sponsor | ||
Hi, I was just wondering if it was possible to set up an all tube amplifier for use after a yaha/soha style SE gain stage. If it can go with output caps instead of trafos that would be nice. Is it possible? I've seen somewheres an EL84 used as a kathode follower with an LM317 set as a 40mA CCS, reminiscent of a szekeres circuit. It had output caps of around 470uF. What would be the lowest b+ I could use? Any help would be awesome
#2 |
If I were to use an el84 as cathode follower I would use 250v across the tube. Thats 250v + voltage across the ccs load. So if you have say 20v across the ccs then use B+ of 270v.
#3 |
any good discrete ccs for that high of a voltage?
| Lundahl+EL84 PP+concertina+input stage | trifidmaster | Tubes / Valves | 63 | 21st December 2008 12:50 PM |
| EL84 as both driver and output stage. | pwan | Tubes / Valves | 29 | 8th April 2008 09:12 PM |
| EL84 PP output transformer for 6L6 PP class A | engels | Tubes / Valves | 8 | 30th May 2007 09:45 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Page generated in 0.06136 seconds (69.78% PHP - 30.22% MySQL) with 10 queries |
